Old 10-12-2005, 02:58 PM   #1
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
Harness removal
I'm pulling the KA main engine harness out of an auto 240SX. It's all disconnected in the engine bay. But something is holding on in the interior (I got all the obvious stuff disconnected like the dash plug, ECU plug etc.) Is there some kind of clips holding it in place behind the dash as well that I need to disconnect? If there is I don't see any. Any help or things I may have forgotten (or don't know are there) would be great. Thanks.
mRclARK1 is offline   Reply With Quote
Old 10-12-2005, 03:14 PM   #2
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
dash & ecu are all there are i think. I just removed mine this weekend, it is tough to pull through the hole, but i didn't find any clips.
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 10-12-2005, 04:28 PM   #3
jedc
jedc is an unknown quantity at this point
Send a message via AIM to jedc
I pulled one not too long ago. IIRC, there is a clip attached to the harness between the dash and the firewall. I would get a flashlight and check under the dash before you go yanking on it.
jedc is offline   Reply With Quote
Old 10-12-2005, 05:18 PM   #4
boarder5516
boarder5516 is an unknown quantity at this point
Send a message via AIM to boarder5516
i took the blower motor out from underneath of the the dash...it made it a lot easier to see what i was doing and easier to work under the dash, cause there is a decent amount of connectors that need unplugged under there.
Shift_Kouki
sr20det powered
boarder5516 is offline   Reply With Quote
Old 10-13-2005, 12:21 AM   #5
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
me and my friends said fuck it and just pushed the harness up and broke it off the clip on our cars
Indolent is offline   Reply With Quote
Old 10-13-2005, 12:34 AM   #6
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Be gentle, this isn't sex!
Theres a dashclip, ECU clip, and the harness itself if ziptied to, IIRC, the dashbrace? But i could be wrong.
SochBAT is offline   Reply With Quote
