Old 04-13-2002, 05:01 PM   #1
ledzep
ledzep is an unknown quantity at this point
What is the difference between an S14 SR20DET redtop and blacktop?  Please let me know all the differences, pros and cons.  Im thinking about doing a swap.  Thanks
    -Daniel
1993 300ZX NA.  Stage 1+
ledzep is offline   Reply With Quote
Old 04-13-2002, 05:11 PM   #2
DSC
New Title
DSC is an unknown quantity at this point
Got this from a few pages back
DSC is offline   Reply With Quote
Old 04-13-2002, 05:29 PM   #3
s14boi
s14boi is an unknown quantity at this point
Send a message via ICQ to s14boi
and just to make it a lil easier for u if you're lazy...
SR20DET specs
if i were u i'd bookmark that site, those guys know quite a bit
it's www.srswap.com
s14boi is offline   Reply With Quote
Old 04-13-2002, 05:57 PM   #4
ledzep
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (s14boi @ April 13 2002,6:29)</td></tr><tr><td id="QUOTE"></td></tr></table><span id='postcolor'>
Is a S15 motor a direct boltup to a S14? &nbsp;Whats involved with the swap? &nbsp;I was just thinking a blacktop S14 engine, 220 hp. &nbsp;I plan on doing a bigger turbo and injectors anyways. &nbsp;Thanks
BTW hopefully this will be in a 97 s14.
&nbsp;-Daniel
1993 300ZX NA. &nbsp;Stage 1+
Old 04-13-2002, 07:12 PM   #5
s14boi
S15 will fit in the same as an S14... if u go S15 most ppl usually use the S14 5-spd instead of the S15 6-spd for stregnth reasons.
but if you plan on upgrade bigger turbo/injectors it'd be more cost efficient to go w/ the older engine it will easily surpass the S15 stock hp by puttin in about the same amount as u would spend extra for the S15 engine. &nbsp;anyway u go about it, good luck an post ur results &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Old 04-14-2002, 10:01 AM   #6
gsrcamel
gsrcamel is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (s14boi @ April 13 2002,8:12)</td></tr><tr><td id="QUOTE">S15 will fit in the same as an S14... if u go S15 most ppl usually use the S14 5-spd instead of the S15 6-spd for stregnth reasons.
but if you plan on upgrade bigger turbo/injectors it'd be more cost efficient to go w/ the older engine it will easily surpass the S15 stock hp by puttin in about the same amount as u would spend extra for the S15 engine. anyway u go about it, good luck an post ur results <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'></td></tr></table><span id='postcolor'>
Never heard of anyone not using the S15 tranny for strength reasons?!? I know 3+ guys that did not use the tranny because a 6spd is exactly what you DON'T want in 90% of all turbocharged cases. Turbos like long gears simply said. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'>
I currently own a 95 Acura Integra GS-R with plans to buy a 240 and throw in a sr20det![br]http://www.angelfire.com/ga4/s14/index.html
gsrcamel is offline   Reply With Quote
Old 04-14-2002, 10:45 AM   #7
rotaryknight
rotaryknight is an unknown quantity at this point
The S15 tranny is not very strong. &nbsp;It only handles about 300 rwhp then craps out. &nbsp;Also from what I know the speed sendor is in the Tranny so it's also a pain to install.
Daily Driver- 91 240 SX SE...S13 Blacktop
HKS FMIC, EVC IV, W/G, Racing Suction, DP, Dual Drager, springs/pillow ball mounts
Whiteline sway bars
Tokico blues
Koyo Radiator, Fluidyne fan
J30 VLSD
stock exterior.
Fun Car- 94 FD3S (TO4S). The White HKS FD in FnF......may she rest in pieces.
rotaryknight is offline   Reply With Quote
Old 04-14-2002, 02:25 PM   #8
crazycuban
crazycuban is an unknown quantity at this point
Blitz S15, with 6 speed, 425 rwhp. &nbsp;It can be done.
crazycuban is offline   Reply With Quote
