How do i compress/decompress my rear brakes?
i'm replacing my rear pads and now it seems like the piston is fully extended out. Making it impossible for me to fit the calipers and the new pads over the rotors.
PLEASE help... |
Admin Asshole
![]() Join Date: Mar 2002
Needle nose pliers.
Place the tips in the grooves on the piston and turn. There is an actual tool to do this, but needle nose work just as well, and most people have them in their tool boxes.
#5 | |
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
the rear calipers got me too when i first worked on them. They screw in and out rather than just push in/out.
HouseBuyers365.com Quote:
#7 | |
![]() Join Date: Oct 2003
clockwise
0qoknmt20igdfvfd
#9 | |
you're welcome
#10 | |
aWingThing.com
![]() Join Date: Mar 2003
Yup it takes forever basically. I've been turning mine for 7 months. JK, but yea it does take awhile. ![]()
What I do for a living...www.mhrussell.com |
![]() Join Date: Sep 2004
me too, when i first work on my brakes, i even don't know when can i finish turning it, LOL
~小アレンのリベリオン~ いくせ, 勝負た! 轟こう, オレのKRMS13!!! オレの得意技!蹴り進入!角度の少ないドリフト! ![]() |
#14 |
![]() Join Date: Feb 2003
Location: PA.....I always thought that dogs...umm...layed eggs, and I learned something today
I bought this for a few dollars, makes it a hell of a lot easier than using the needle nose pliers
#15 |
where did you buy that tool/bit from? holy hell, i finally got one side.... but yeah, do tell me what that things "official" name is so i can find one for either the other side or for future uses.
#17 |
they also have the more universal one shaped like a box...did you take the BMC cap off? shouldnt really be a two nite thing...it also helps sometimes to twist with pliers and simultaneously push down mms at a time with a c-clamp...
s14| y34| 911 gts| exige s| 600rr| r3| 250r| 85 girlfriend ![]() |
#18 | |
do you have to keep the name of the tool secret and only exchange it by PM?
#20 | |
Anyways, if you wanna know the name of the super ultimate secret brake tool, here it is. It's just a 4 wheel disc brake caliper tool bought from a local auto parts store, here's a pic of the packaging: ![]() no super fancy name, just plain and simple... |
#21 |
when your turning them in, it helps alot if you break the dust seal loose from the piston first, otherwise it sticks, winds up, and binds while turning it in. Just use a little flat head screw driver and slide it between the boot and the piston all the way around. Lubing it with a few drops of brake fluid might help too (don't use anything else!), but I usually get away with just breaking it free.
ASE Master Technician |
#22 |
well i got both of the rears done. i did have to lub up the dust boot/seal, but i sprayed some PB Blaster on it instead of using brake fluid. that was the only thing i had to use. hahaha. havent tested out the brakes on the road yet. we'll see soon enough. =)
thank guys. hopefully the fronts are much easier. |
#24 |
![]() Join Date: Dec 2002
If they took that long, they're junk. They'll be seizing completely pretty soon so start saving for remans now.
#26 |
I bought a caliper tool set from Harbor Freight for $20 when it was on sale. Sad part is that I haven't had a chance to use it since I always forget it in LA while I'm working on my car is San Diego.
http://www.harborfreight.com/cpi/cta...emnumber=40732 Also I had to take a hammer to the piston because it was seized. After a few knock it started to retract using the plier method. |
#27 |
I have the "Box" type caliper tool, and I just hook it to my 18 volt drill and go to town, it's got enough torque that it sqeezes the fluid out in a big arcing jet across the garage!
MMM, Dido.... 1997 240SX SE S15 SR20DET |
#28 |
![]() Join Date: Apr 2004
Tips:
* Check to see if the boot is torn or if the piston is pitted. The piston should be flat and straight, without any dents/nicks in it. Replace both calipers if one is pitted. It's a common problem on old Nissans and they run $60 apiece so it's not a big deal. * Don't forget to release the parking brake. * To make it easier to retract, loosen the bleeder bolt and put a tube on top of it to catch fluid. It will depressurize the system and make it easier to push the piston back in. Also the fluid that comes out will most likely be really dirty and contaminated. You don't want that in the caliper. Just make sure you don't step on the brake pedal with the bleeder open so it doesn't suck in air. * Use the tool or needle nose pliers. It'll take some time. Be patient and don't rip the boot or hurt yourself. Turn clockwise. * Spray some brake cleaner to clean out dirt from the boot. It will help the piston retract. |
#29 |
![]() Join Date: May 2005
both my rear pistons look like crap...boot is torn a little on both sides. Pitted up pretty good too. Good thing I have an extra set...lol
'93 Coupe BlkTp-SR '07 Chevy HHR - DD |
