5zigens fno1rc won't clear
17x8+35 5zigens fno1r-c barely won't clear my tein he coilovers in the front. Has anyone else had this problem? should I use spacers or trade wheels?
s13 |
![]() Join Date: Mar 2003
![]() ![]() Feedback Score: 1 reviews
an indepdent tire shop or motorsport place.. shouldn't matter..about the adaptor..but..if you take it to like cosco or sam's club or somethign like that..they would bitch because usually only mount tires and rims on oem spec..they will not work on your car because they can't risk the rim falling off or something hapening to your car if not mounted correctly..
-Cherry Red 91 Silfourty- ![]() |
thanks, has anyone dealt with this product http://onetongarage.com/products/whe...cer/index.html ?
The guys from one ton are cool
i heard they make a lot of Scion parts as well Max
[email protected] 1-866-327-7399 |
#16 |
I used to have 16x8 +30 with Tein HE (with 205/50/16). If I had the coilover set to max positive camber at the slotted holes that attach to the spindle, the tire would clear the coilover. If I had it pushed all the way in (max neg camber), the tire touched.
Another +1 for OTG. EDIT: I meant camber, not caster... Last edited by LH1-Hatch; 10-23-2005 at 03:28 PM.. |
#17 |
My 17x8 +35 clear my D2's fine, not much clearance though. I couldn't clear it with anything larger than 215/45 though. I'm going to pick up a small spacer as well though so I can squeeze a 245 under the front.
#18 |
![]() Join Date: Apr 2005
D2s are different. the bracket that attaches to the spindle is different. You can't verify that D2s work when HEs won't just like how my N1 pros work with 17x9 +20. Just go with a 10mm spacer, but I'm worried about having enough threads to use to be safe.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!! ![]() formerly sideviewcivic Save a Horse. Drift This Cowboy. AirBag Club Member #0014 ![]() |
