Old 04-15-2002, 10:52 AM   #1
Tyler Durdan
Tyler Durdan's Avatar
Tyler Durdan is an unknown quantity at this point
Does anybody know where to run the power cable through the firewall on a 97 240 SX SE? &nbsp;Any suggestions? &nbsp;I am at the point where I am getting ready to take a drill to the damn thing... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/hmmm.gif" border="0" valign="absmiddle" alt=':hmmm:'>. &nbsp;Thanks for the help in advance.
&quot;Pure adrenaline attached to a license plate. &nbsp;Isn't it time to experience one yourself?&quot; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; -Dan Gurney
Turbo for Sale
Tyler Durdan is offline   Reply With Quote
Old 04-15-2002, 11:57 AM   #2
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
there is a hole/plug oon &nbsp;both the driver and the passenger side......
look for a plug in the firewall
I am GOD!
drifterx is offline   Reply With Quote
Old 04-15-2002, 01:10 PM   #3
Tyler Durdan
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (drifterx @ April 14 2002,1:57)</td></tr><tr><td id="QUOTE">there is a hole/plug oon both the driver and the passenger side......
look for a plug in the firewall</td></tr></table><span id='postcolor'>
Yeah...I came across the driver's side plug...but I couldn't get the bastard to come out so I could slide it in. &nbsp;I was wondering if there is any other way through the firewall....thanks for the suggestion though.
Turbo for Sale
Old 04-15-2002, 01:23 PM   #4
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
i drilled the damn thing on my s13 =b
or, a good idea i adapted was to run the wire under the car, and move battery to the trunk.
so now i have a hole in my firewall for my fogs =b
240meowth is offline   Reply With Quote
Old 04-16-2002, 03:20 AM   #5
9524tee
9524tee is an unknown quantity at this point
Send a message via AIM to 9524tee
just put a small hole in it then silicone it make it real tight and clean looking ,it worked on mine
Nancy Kappa Monkey Squad
9524tee is offline   Reply With Quote
Old 04-16-2002, 10:49 AM   #6
gschroeder78
gschroeder78 is an unknown quantity at this point
Send a message via Yahoo to gschroeder78
I just wired my amp (just to power the normal speakers) nd I used the plug on the passengerside to get through the firewall. I won't drill into the body unless I absolutly have to. IMHO if it's not worth doing right, it's not worth doing at all.
1989 240SX Coupe
-Eibach Prokit Springs
-KYB AGX Struts
-Apex-i N1 Dual Exhaust
Westminster, CO
gschroeder78 is offline   Reply With Quote
Old 04-17-2002, 08:09 AM   #7
WaKeMaN
WaKeMaN's Avatar
WaKeMaN is an unknown quantity at this point
Give this a shot.
On the passenger side (in engine bay) there is a large grommet with a bunch of stuff going through. &nbsp;Inside the passenger foot well, remove the glove box, and kick panel.
Then attach your power wire (with duct tape and a good bend) to a straightened coat hanger. &nbsp;Try to make it as slim a profile as possible. &nbsp;Use an exacto knife to make a small incision in the grommet between the metal of the firewall and the bunch of wire. &nbsp;This is your guide hole. &nbsp;Now just push that sucker through. &nbsp;Your coat hanger should pop into your passenger footwell without too many problems. &nbsp;The hole should also be real tight against the power wire (no leaking).
I know it sounds ghetto but it worked for me. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
Previous Car: 1994 Z28
Current Car: 1997 240SX SE 5sp (OBX FSTB, N1 Dual, pondering Greddy Turbo Kit...)
I'm just another one of the ever growing list of V8 defectors.
WaKeMaN is offline   Reply With Quote
Old 04-17-2002, 08:19 AM   #8
sykikchimp
WOW addicted
sykikchimp's Avatar
I have to run 4ga for my 2 amps, so what I'm probably gonna do is buy a real nice grommet like the PhoenixGold one, and just drill a hole in the firewall and put my own grommet in there. &nbsp;That way (as 240meowth said) I'll have a spot for my power wire, and my fog light switch wires (once I get them)
It'll look real clean and keep the seal.
looks like this:
Old 04-17-2002, 11:05 AM   #9
gschroeder78
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (WaKeMaN @ April 17 2002,08:09)</td></tr><tr><td id="QUOTE">Give this a shot.
On the passenger side (in engine bay) there is a large grommet with a bunch of stuff going through. Inside the passenger foot well, remove the glove box, and kick panel.
Then attach your power wire (with duct tape and a good bend) to a straightened coat hanger. Try to make it as slim a profile as possible. Use an exacto knife to make a small incision in the grommet between the metal of the firewall and the bunch of wire. This is your guide hole. Now just push that sucker through. Your coat hanger should pop into your passenger footwell without too many problems. The hole should also be real tight against the power wire (no leaking).
I know it sounds ghetto but it worked for me. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
I don't think it's ghetto. Thats exactly how I ran mine and it worked perfectly. Best of all, no drilling.
1989 240SX Coupe
-KYB AGX Struts
Westminster, CO
Old 04-17-2002, 12:57 PM   #10
Tyler Durdan
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (WaKeMaN @ April 16 2002,10:09)</td></tr><tr><td id="QUOTE">Give this a shot.
Sounds like it'll work....I'm going to give it a shot this Saturday and I'll let you guys know.
Turbo for Sale
Old 04-17-2002, 01:20 PM   #11
gschroeder78
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Tyler Durdan @ April 17 2002,12:57)</td></tr><tr><td id="QUOTE">Sounds like it'll work....I'm going to give it a shot this Saturday and I'll let you guys know.</td></tr></table><span id='postcolor'>
If you want to make it easier, take off the right fender liner and it will give you easier access the plug. I just did all of this a week ago. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
1989 240SX Coupe
-KYB AGX Struts
Westminster, CO
Old 04-17-2002, 06:31 PM   #12
silvia lover
silvia lover's Avatar
silvia lover is an unknown quantity at this point
one question, since the desk only come with one remote wire, and you have 2 amps, how you gonna wire to both amp to make it work. OR even if you have a extra cap( i'm gonna put 2 1 farad cap for my 2 amps). And this question just pop up in my head. It sounds like stupid, but i really want to know it, because i'm gonna put all the amps, and caps in at once soon. thanks for reading it.
silvia lover is offline   Reply With Quote
Old 04-18-2002, 05:06 AM   #13
guidot
guidot is an unknown quantity at this point
Send a message via AIM to guidot
Being an install tech, the "proper" way for us to do it was to drill a hole in the firewall. &nbsp;You may need two grommets, because the firewall is double deep. &nbsp;I ran 4g to the back via the passengers side, and ran RCA's on the drivers...
:silvia lover: You can split that one remote wire into two no prob... &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
-Jeff T. 96 240SX
240SXONE
http://www.240sxone.com
guidot is offline   Reply With Quote
Old 04-18-2002, 08:50 AM   #14
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
If you drill a hole, you may wanna use a rubber grommet to line the hole. &nbsp;A grommet is one of those rubber doughnut lookin things thats usually no bigger than a dime, and is placed in drilled holes so wires can come out and not become frayed over time by rubbing on the sharp metal lip of the drilled hole.
M
400x200
mbmbmb23 is offline   Reply With Quote
Old 04-18-2002, 08:50 AM   #15
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
Oops...guidot beat me to it.
400x200
