Old 10-29-2005, 12:19 PM   #1
sr20drft
sr20drft is an unknown quantity at this point
Transmission problems..... yes or no?
Alright, it's been about 6 months driving like this and it has got to stop asap....... I've searched and searched, there are a couple things I have in mind, but just wondering if anyone can help me here.
sr20det redtop tranny and lsd / exedy hyper single clutch kit.
Ok onto the symptoms, sometimes it will grind and pop out of reverse, unless I go into 1st and then into reverse. Often, there is a smack/clunk sound when the clutch is engaged and disengaged quickly. Lastly the most annoying and possibly the worst problems? On deceleration, at around 3k-2k rpm, it chatters like crazy, like to the point where it's louder than my exhaust. Finally, above 3500rpm on acceleration, it also chatters/rattles like crazy, making me not want to push it upwards of 4k+.
One thing I have noticed, it seems like it drives a lot smoother after it has been sitting over night and is cold....... rather odd I think.
So if any of you have any insight to what is going on, please reply, because I'm at the point where I'm about to pick up a new transmission with a much, much softer clutch.
Thanks.
sr20drft is offline   Reply With Quote
Old 10-29-2005, 12:32 PM   #2
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
It might just be that your clutch has to be readjusted, so it tries to slip sometimes. but since that's upgraded too, you get chatter instead.
might be wrong though good luck
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 10-31-2005, 03:17 PM   #3
sr20drft
update, drained tranny fluid and a hunk of metal came out........ I don't think that's supposed to happen haha, anyways, anyone know what the hell this metal piece is that came out of my tranny?
Filled it back up with heavy shockproof, still chatters like a bitch and drives like crap
Old 10-31-2005, 05:17 PM   #4
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
sounds broken... might wanna start lookin for a new transmission
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 10-31-2005, 08:02 PM   #5
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
your tranny is toast if a chunk of metal that size came out of it . Look at this way, most likely one of your shift forks is damaged, that piece of metal is the example. That has been bouncing around inside your tranny . think if it gets caught in gears think of the damage it can do.
New Video
Buy my mounts!
Old 11-01-2005, 11:27 AM   #6
sr20drft
my thoughts exactly, but I'm just trying to think what could have caused this, since right after I had my clutch installed, it was driving like a pos
Old 11-01-2005, 11:40 AM   #7
silviadriftr
silviadriftr's Avatar
silviadriftr is a well-known jackass
Send a message via AIM to silviadriftr
[QUOTE=sr20drft]update, drained tranny fluid and a hunk of metal came out........ I don't think that's supposed to happen haha, anyways, anyone know what the hell this metal piece is that came out of my tranny?
Filled it back up with heavy shockproof, still chatters like a bitch and drives like crap QUOTE]
That is a shield that redirects trans fluid inside the trans. Not a piece that will keep it from running but it directs it up into the are where the shifter is so after a period of time the shifter may become harder to move. Sounds like and adjustment problem on the chattering like th clutch plate is releasing away from the pressure plate and then gripping again. Possibly a weak throw out bearing.
UNLIMITED PERFORMANCE
WWW.TURBODAVE.COM
http://www.mountainboost.com/415/silvia.wmv
Record holding-473whp-sr20det
stock cams and bottom end
silviadriftr is offline   Reply With Quote
Old 11-02-2005, 02:05 PM   #8
sr20drft
alrighty, adjustment problem as in adjusting the the clutch from under the dash?
if so I'll give that a try.
