Old 11-04-2005, 08:51 PM   #31
Ritz S14
Ritz S14's Avatar
Never once hit 300 miles a tank. If I EVER hit 300 miles a tank.. I'll take a pic of it and rejoice.. bwhahah.
How about this. How far does the needle go down before you're EMPTY on gas? I freak out as soon as I touch the las black line.. then I get some gas..hahaha
Ritz S14 is offline   Reply With Quote
Old 11-04-2005, 09:33 PM   #32
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
I get around 300+ mixed driving 340ish all highway. This is on 87-89 octane with the gas prices going up I only used the good stuff for race day.
Slide Happy
chuy is offline   Reply With Quote
Old 11-05-2005, 03:20 PM   #33
Xren17
Xren17 is an unknown quantity at this point
Everyone is calculating per tank. Just curious because, how I do it is, I fill up and set my trip meter to 0. Drive around until I have to fill up again and then calculate MPG. It seems to me that trying to determine MPG per tank is rather inaccurate unless you drive until it dies.
Xren17 is offline   Reply With Quote
Old 11-05-2005, 03:28 PM   #34
Ritz S14
Ritz S14's Avatar
^ not true at all. Check your receipt. The amount of miles divided by the amount of gallons purchased.
Old 11-07-2005, 01:22 PM   #35
Xren17
Come by me again? Isn't that what I said? That you have to start with a full tank of gas. Drive around and then fill up before you can determine your MPG. Otherwise, you can't really determine how much gas you've used. Maybe I'm missing something.
Old 11-07-2005, 01:55 PM   #36
Nostradamus
Nostradamus's Avatar
Nostradamus will become famous soon enoughNostradamus will become famous soon enoughNostradamus will become famous soon enoughNostradamus will become famous soon enoughNostradamus will become famous soon enough
You said it's inaccurate unless you drive till it dies which is not correct. You can fill up(make sure you stop filling when the pump stops), set your trip to zero, drive around then fillup. Divide the amount of miles driven by gallons and there you go. Surely this is not 100.00% accurate but it's pretty close.
Nostradamus is offline   Reply With Quote
Old 11-07-2005, 02:49 PM   #37
Xren17
Nosterdomis,
I totall agree with you because that's how I said to do it. What I said above, was that it is inaccurate if you "tried to determine MPG per tank ."
Old 11-07-2005, 02:52 PM   #38
floodshark
floodshark is an unknown quantity at this point
If it makes you feel any better my S13 is getting about 150 miles per tank.
floodshark is offline   Reply With Quote
