#31 | |
![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
haha, yeah the rotor is flat aainst the hub and held there with a lugnut for the shot, and yeah I did think about a hydro Ebrake, my buddy has the Arizona kit pictured above on his 72 240Z, but Im going to try to get the an internal one to work first, we'll see, just begining this and I'll add more as I work it out. Probably just use a Z32 MC/Booster, they work just fine ![]() |
#32 |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() Feedback Score: 20 reviews
awesome job man, not only will they stop well but they will look awesome.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
#34 | |
Signature Exceeds Forum Limits |
#35 | |
#36 |
haha, tits! just did some reserch online and it looks like the 300ZX uses the SAME size E-brake Drum as the EVO (172mm) so it looks like these should work just fine with Z32 E brakes!
![]() someone with a 300zx rears meet up with me so I can confirm this! ![]() |
#38 | |
#40 |
![]() Join Date: Jun 2001
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
sorry if this has been covered, but if you do go with a separate caliper ebrake, where will you mount it? just curious cause i've been thinking about that setup.
18+ to come//21+ to swallow |
#42 | |
#43 | |
#44 |
I think z33 calipers can bolt on, there is a guy running them on his s14.
Search, I'm sure it's been posted on here. I think dousan knows him.
Scott Driving Angle Motorsports |
#45 |
![]() Join Date: Mar 2002
http://forums.freshalloy.com/ubbthre...e#Post67829059
http://forums.freshalloy.com/ubbthre...e#Post67836239 http://forums.freshalloy.com/ubbthre...vc=1&PHPSESSID = http://home.comcast.net/~nzo/GTR_bra...TR_bracket.pdf
sentinelguild.com/nzo/PFCDB/ |
#46 | |
haha, awesome! looks like the 350Z/G35 fronts fit by opening up the bolt hoes a bit ![]() Now the only prob is finding those brakes, they're not quite as common as the EVO/STIs, also they are the smaller Brembo so Im not sure how well they would ballance with the rears. Though if I could find them for the same price that I see the EVO/STIs I would run those instead! ![]() |
#48 |
Any idea how they compare in size (front and rear, especially rear since you have already done them) to the Z32? How do the evo/sti compare to 350/g35 I wonder how much bigger than the Zs they are...
they do look good... keep us up to date on the z32 ebrake set up... thanks, mmtmatrix |
#49 |
![]() Join Date: Jan 2005
hey Krinkov. i just noticed that caliper has bleeder screw at teh bottom. one thats pictured is on driver side and if you put it on pass then bleeder will be facing up and it should bleed hella better.
#50 |
![]() Join Date: Aug 2002
interesting and informative post. faq?
just wondering, what kind of rear ebrake setup do sti/evo use? drum setup like z32? not integrated disc setup like stock 240sx since you would have hooked those up right? |
#51 |
This box is 400x200: ![]() Please do not put your sig pic back if it exceeds this. -Moderation Last edited by phrozen; 11-05-2005 at 01:01 AM.. |
#52 | ||
![]() Join Date: Feb 2002
Keep us posted.
Goals are dreams with a deadline. L.H.O.O.Q. |
#53 | |
#54 |
heres the front comparison,
pinter stock discs :ghey: ![]() hairy chested EVO Brembos ![]() ![]() and just for shnitz and giggles, heres a Cobra 13" rotor, right bolt pattern but doesnt center perfectly on the hub and studs like the EVO rotor, guess I'll have to do with 'only' 320mm EVO rotors ![]() ![]() heres the side by side ![]() these are REALLY big ![]() ![]() |
#55 | |
#57 | |
Little update: Looks like rear EVO Brembo calipers DO NOT fit onto the rear hubs like the STI Brembos do. The Rear EVO Brembo bolt spacing looks to be about 1/2" too wide, so if you keeping an eye out pick up the STI rear, though you will still need the EVO rear rotors. As for fronts, EVO and STIs are supposedly identical, in any case, I should have a set of STI Brembos off my car other car to play with this weekend ![]() |
#58 |
Okay UPDATE!!
Man this swap just keeps getting easier! ![]() Picked up another set of STI Brembos yesterday, and it looks like our best route will be to use the EVO front rotors instead of the 05+ STIs(5X114) the STIs use a smaller center hub opening that wont fit whereas the EVO is spot on, so we'll stick with plan A. Heres what the EVO rotors look like with the STI Brembos, oooooooooohh! ![]() ![]() Brembo F50 calipers are truely MASSIVE, much larger that what in hand than what you can see of the sides of them poking through the spokes of a wheel. ![]() Now about the easy (*fairly*) easy part I mentioned, looks like the brackets are going to be simple to fab up, matter of fact thay can be made yourself if you have a quality drill press and drill vise, no machining necisary! Most big brake kits have brackets shaped like kind of like an "S" since the new caliper and has be moved up and backward(inwards) to bolt to the stock caliper volt holes. In our case with these Brembos and EVO rotors, the Brembos sit a good .6" outwards ofthe stock bolt hols, on top of that, the stock bolt spacing(4") and the brembo bolt spacing(6") are far enough apart that we can make the bracket on a single-plane bracket, instead of a dual-plane bracket which requires much more design and machining, see here ![]() ![]() ![]() heres a quickie MS paint diagram of what the single-plane bracket will look like, not to scale obviously but the measurements are correct, Im going to fab one out of aluminum tonite to get everything where I want it then I will make mine out of mild steel. I know alot of the brake companies use 6061 AL with no probs but mild steel gives you that much more insurance, and its not that much harder to work with. Okay I'll post mor eas it progresses! ![]() ![]() |
#59 |
![]() Join Date: Apr 2005
I love it when a neighbor totals an STi and lets me have a grab bag on his car, hehe
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!! ![]() formerly sideviewcivic Save a Horse. Drift This Cowboy. AirBag Club Member #0014 ![]() |
#60 | |
haha, yeah grab those Brembos! And if you need a set of EVO rotors let me know! ![]() |
