Old 11-14-2005, 08:51 PM   #1
sifu
sifu is an unknown quantity at this point
missing stuff on tranny
i got a tranny for my 5 speed swap but everything is missing on it.. like the throw out bearing assembly, sensors, and switches
what should i do? buy a new tranny?? or buy everything
sifu is offline   Reply With Quote
Old 11-14-2005, 08:52 PM   #2
ALTRNTV
I would just buy the stuff you're missing. Worse comes to worst, sell the tranny and buy a complete one.
ALTRNTV is offline   Reply With Quote
Old 11-15-2005, 06:25 AM   #3
sifu
this is my bellhousing.. you put the throw out bearing on that shaft right? is there anything else i'm missing besides a fork? is there a second part to the TOB? i was told that the throw out bearing is too small and theres something that mounts it on.
Old 11-15-2005, 11:39 AM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
release bearing, release sleeve, holder spring, retainer spring, withdrawal lever(fork)
Old 11-15-2005, 11:47 AM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
don't really need all the sensors, just reverse lights if you car, speed sensor for speedometer, and nuetral position switch might be useful
Old 11-15-2005, 01:08 PM   #6
aznpoopy
aznpoopy's Avatar
before you do the swap make sure you put on the rear extension seal and the gasket thats right behind that plate in your pic.
Old 11-15-2005, 09:53 PM   #7
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
Before you do the swap read every thing that you can find on doing it. There are several very good posts on doing the swap in archives. By the way I would try to find a switch for reverse lights from somone, new OEM from Nissan they are $45.00. http://www.zilvia.net/f/showthread.p...ighlight=trans This is a great thread.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 11-16-2005, 11:26 PM   #8
sifu
thanks for the help and for the pic
would they have some of the parts i need at a nissan dealership?
Old 11-17-2005, 01:47 AM   #9
NemeGuero
No more nissan.
NemeGuero's Avatar
yes, or here. www.courtesyparts.com
if it's not listed, call..
Old 11-17-2005, 02:22 AM   #10
projectRDM
projectRDM's Avatar
No, Nissan dealerships don't sell Nissan parts.
FORMERLY R240NA
Old 11-17-2005, 11:33 AM   #11
sifu
i went to http://www.overnightautoparts.com/
i'm ordering a Release Bearing Retainer Spring and release bearing holder for a total of 20 dollars.. do i need a clutch release arm also? i have a fork and TOB already
Old 11-17-2005, 02:21 PM   #12
NemeGuero
No more nissan.
NemeGuero's Avatar
clutch release arm = fork
Old 11-17-2005, 07:35 PM   #13
sifu
lol thanks man
Old 11-18-2005, 02:40 AM   #14
NemeGuero
No more nissan.
NemeGuero's Avatar
no problem
Old 11-18-2005, 04:26 PM   #15
sifu
i got these in the mail today.. what are the sensors from left to right?
Old 11-18-2005, 04:45 PM   #16
Jonnie Fraz
Trader Rating: (29)
Your pic needs a little help, but I think the first one is your reverse light switch. If you have a continuity tester check across the two wires both without pushing on the switch and depressing it. Without depressing switch= no continuity. Depress switch = continuity, then switch is good. That should work for all the switches. Only one you realy need is reverse lights, the others will fill the holes in your tranny nicely.
Old 11-20-2005, 09:30 PM   #17
sifu
alright i finally got all my parts together.. here's what i have
i have:
Manual Transmission
Shifter
Release Bearing
M/T Mounting plate
Clutch pedal
Crossmember
Driveshaft (other half not in pic)
Brake pedal (From M/T car)
Clutch master cylinder
Clutch slave cylinder
Hydraulic Lines: i only have the rubber one attached to the clutch slave
Shift boot and plate
96 Manual ECU that i'm not going to use because I have a '97. I'm going to go with the Auto ECU until i get a 97/98 Manual ECU
already installed on my car-
Pressure plate
Clutch
Flywheel from a m/t
stuff i have for the missing parts on tranny-
clutch fork
clutch alignment tool
dust cover
release bearing
ordered a release sleeve and a retainer spring
some sensors in the other pictures but i dont know which they are.
here is what my tranny looks like..
is there anything else i'm missing besides a speed sensor and clutch hardline?
i've searched through a lot of manual swap guides but none really answer my question. i spent a lot of time on this post, so if you guys could help me, i'd really
appreciate it.
thanks
Old 11-20-2005, 11:10 PM   #18
NemeGuero
No more nissan.
NemeGuero's Avatar
Did you switch out the pilot bearing before you installed the clutch and pressure plate? If not, yank 'em off and DO IT. And where the heck is the rest of your slave cylinder? The pushrod and such? Where and how much did you get s14 pedals for? And your s14 tranny.
And do you have both springs?
Old 11-20-2005, 11:30 PM   #19
sifu
i got everything for 800 in one package
the clutch slave cylinder.. i bought a brand new one from overnightautoparts.com
that one in the picture just came with the package
both springs to what? if it is the tranny you're talking about, i ordered a retainer spring
i might be buying a 98 manual ecu soon, it'll just hook up to my harness i have right now right?
anything else i need?
thanks neme
Old 11-21-2005, 12:20 AM   #20
NemeGuero
No more nissan.
NemeGuero's Avatar
Tha's it.. and where did you get those pedals/package?
Old 11-21-2005, 09:53 AM   #21
Jonnie Fraz
Trader Rating: (29)
Looks like you are on the right track. If I may make a suggestion, I would suggest that since you are there you might want to change out your rear main seal, also the front and rear seals on the tranny. Rear main is about $25.00 and the tranny seals are about $5.00 ea aftermarket. I got mine at NAPA.
I see that you have your auto trans out...I know that was fun. Good luck with your swap I just finished mine. Be patient getting the manual back up in there can be a bit of a bear...My s13 was a little tricky, it may be different for the s14
Old 11-21-2005, 10:01 AM   #22
NemeGuero
No more nissan.
NemeGuero's Avatar
Nope, its just as much a pain as the s13.
Old 11-21-2005, 11:03 AM   #23
sifu
should i buy a 98 manual ecu for 100? and then sell my 96 ecu?
how is your car running jonnie?
Old 11-21-2005, 11:14 AM   #24
NemeGuero
No more nissan.
NemeGuero's Avatar
NO NO NO NO NO for $100?! I paid $30 for a 95 and $40 for a 96 ecu SHIPPED!! Hold out until someone less stingy is selling a 97-98 ecu. haha
and reply to my PM damn you!
Old 11-29-2005, 03:43 PM   #25
sifu
what is the crossmember mount? or is that the same as a transmission mount?
someone said i needed one and it costs 100 bucks..
Old 11-29-2005, 04:13 PM   #26
NemeGuero
No more nissan.
NemeGuero's Avatar
Yes, same as tranny mount. I paid $15 for mine FYI
Old 11-29-2005, 07:16 PM   #27
sifu
did you get yours at a salvage yard?
Old 11-29-2005, 07:24 PM   #28
NemeGuero
No more nissan.
NemeGuero's Avatar
No, from these boards.
Old 11-30-2005, 02:42 PM   #29
jd-17
jd-17 is a well-known jackass
Send a message via AIM to jd-17
s13 swaps are easy.............
good luck with this swap
jd-17 is offline   Reply With Quote
Old 11-30-2005, 05:41 PM   #30
Buttasc0ttch
Buttasc0ttch's Avatar
Buttasc0ttch is an unknown quantity at this point
Send a message via AIM to Buttasc0ttch
I just got my 5spd. done. I took it in on Nov. 23rd., recieved it Nov. 26th, all I had to do is supply them with a d/s. The whole thing cost me 600.00, thats (install+parts), the car runs like a dream! I was gonna gather all the parts myself and just pay for installation but a friend of mine told me just to let them do it b/c they know what parts are missing/broken/wearing out/etc. Now I'm happy to drive my car again, glad it is no longer automatic!
Buttasc0ttch is offline   Reply With Quote
