![]() Join Date: Jun 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
sr done for? try to push start but wheels won't roll
ok this is all i know, my friend bought a s13 with a blacktop sr in it, guy said it was running but he blew the motor or whatever, cylinder #3 has low compression 60 i believe, and i think he had another sr before the one in the car and the same problem, cylinder #3 low compression, he ran the stock fuel pump, so i assume this guy leaned out the motors which caused em' to blow, the car's been down for 6 months, but yeah starter is bad supposedly, doesn't make any sound or want to click or anything to turn the car on..
but when we try to push start it, we put it in gear and the damn wheels are locked up, they dont' want to roll at all, the motor done for? i'd think so, maybe the motors frozen or something rusted lol we're gonna try to turn the crank tomorrow w/a socket to help determine the problem(s), just tyring to see any other problems/solutions, let me know what you guys think the problem(s) would be |
![]() Join Date: May 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
you need another longblock assymbly... basically the motor is seized. i bet you one of the pistons is cracked and has coolant in it.
your friend got shafted.
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings?? |
#3 | |
![]() Also I don't really think that the guy got shafted, looks from the description that the seller disclosed that he blew the engine to the buyer. |
![]() Join Date: Aug 2005
Yeha when I roll the car we have in in gear but we have the clutch in. so it roll fine. then when we get some speed we pop the clutch and the wheels just lock up. so I donlt know the car rolls fine when not in gear. Any other options to see if the Engine os frozen?
![]() Join Date: Mar 2003
pull the sparkplugs and shine a light into the cylinder and see what's going on in there.
if its filled with coolant or gas it will also be 'locked' if you leave the spark plugs out and try to crank over the engine by hand and it still doesn't move, then you may want to find the previous owner and beat the snot out of him. |
#6 | |
![]() Join Date: Sep 2003
get a new block if it's locked up.
you can try pulling all the plugs like Aznpoopy said, then try to pop the clutch while rolling. It shouldn't have enough compression to lock up the wheels at that point. Then you know it's seized.
Hi |
#8 | |
![]() Join Date: Dec 2002
![]() Join Date: Feb 2005
Any cracks in the block? Maybe one of the rods broke in half? If your wheels lock up most likely it's seized or you have a broken rod(s) You don't have a choice but to replace the engine either way because that's a major issue that isn't easily fixed by the wave of a magic wand.
I've seen SR blocks that are pretty affordable or you can just rebuild the current one to be bullet proof, I don't know about 16 y.o. proof. ![]() |
#10 | |
#11 | |
![]() Join Date: May 2002
1990 240sx 5spd fastback |
![]() Join Date: Jun 2004
come on guys give him a break.
just get a longblock, borrow money from mama. rebuild the blown block too. and keep it or sell it.
hydropgrahics! ![]() ls1...... |
![]() Join Date: Jan 2005
Trader Rating: (29)
Bardabe...sorry to hear about your bad investment. Sounds to me like you will need another short block at least, like previously posted. Just a little information, if the starter will not spin the motor then you have a problem, but by trying to push start it you may have caused a bigger prob. First thing you should have done was pull the plugs and try to crank it with a socket. By push starting you could have bent a rod or valves or God knows what else. Your first problem may have been as simple as hydrolock in 1 cylinder. Building a project car on a part time buget can be very taxing, you might want to do a little more research before jumping into things.
#14 | |
#16 |
Yeah guys the starter is bad. I took it to get tested and it;s shot. so now uh yeah I need a strter. i'm gonna give the car an oil change, take off all teh spark plugs and try to spin the crank with a socket. what size is the socket?
#17 |
OK uh good day today (sort of) uh we are able to turn the crank with a socket so I know the engine is not locked or Frozen. We didn't even have to remove the spark plugs so yeah I guess its not that bad. uh yeah starter is dead, so I need an SR20 Starter uh what starter fits it other than the Pretty penny RWD SR20 Starter? I also need a fuel pump.
![]() -BArdabe |
#18 | |
Man w/ CTSV & a Car Seat
#20 |
![]() Join Date: Apr 2004
![]() ![]() Feedback Score: 2 reviews
if you can turn the crank with the plugs is there IS a problem. Unless its an impact wrench or a 4 foot breaker bar thats a metric ass load of compression to turn over by hand. Honestly, pulling an SR is cheese. Pull all the hoses (a/c and power steering if so equipped)Just label the plugs on the wiring harness before you pull them, take pics with a digital camera so when you put it together you arent scratching your head, 2 14mm nuts for the motor mounts, 4 17mm bolts for the transmission mounts and the motor is ready to pull out. Once its out, Id send it to a qualified egine rebuild shop. You're on the west coast, they're everywhere.Watch out for shady backyard shops, im sure they're there too. Save some pennies and living cheap will pay off when you get the SR all done and a nice quick running car. Just dont tear into it, screw it up, and have to sell it off on the board for peanuts cause you fucked up.
Goodluck |
#22 | |
#23 |
If your friend is under 18, I would not suggest keeping the car.
There are laws that prevent adults from taking advantage of minors in regards to sales. (That is why you won't be able to buy a new car at a dealership without a co-signer) I'm going under the assumption that this is an S13, bone stock, with a non-running engine for $3000. Which is butt rape. I wouldn't even pay that much for a running stock S13. If you can prove that the true market value of this car is a lot less than what he sold it to you for, and prove that he knew the motor was seized and unrepairable when selling it to you, you can say that he had an unfair advantage on you. And legally, you could give the car back to him and get your money back. Go look up those laws, I have them somewhere in my legal book but I can't find it at the moment. Good luck with the car if you choose to keep it.
White '90 S13 Fastback (SOLD in '07) |
#24 | |
Trader Rating: (29)
Something else bothers me, if the motor is not locked up why were the wheels locking up when they tried to push start it? Tranny locked up? |
#25 | |
Your right Jonnie sounds like the tranny is BAD! |
#26 |
ok today, got the motor to crank/turn with a 27 socket wrench, it turns, now i'm assuming the tranny's fucked? wheels locking up or whatever.. like some of you guys said too lazy to quote, and the intake mani's filled with gas, took off that pipe extension thing that attaches to the compressor for the intake tube, there was oil in laying around, any suggestions towards that, we're planning to tear apart the motor and basically do a mild rebuild/maintenance/sealing it up and what not while it's out
#27 |
Trader Rating: (29)
Well guys sounds like you are in for a major rebuild. Looks like you have a couple of options: (1)Buy another SR motor and tranny, but you still do not know what you are getting into. (2) rebuild the one you have, motor and tranny. This option will be more expensive, but in the end you will know what you are in for. Kadeturbo I think you are right this car needs to go to a shop to have it figured out, truly I do not know you guys, but it sounds like you may be in over your head.
Good luck with your project |
#28 | |
while we're talking about an engine/trans, we have some nice working ka trannies laying around.. iirc the ka transmissions will work with the sr just as long as you swap the bellhousing right? i know i should search but im lazy and there's always someone who'll answer anyway thanks in advance |
#29 | |
Trader Rating: (29)
From the stuff that I have read the transmissions will swap as long as you swap bell housings like you thought. From what I understand it is involved ,but possible. I have not tried personally. |
#30 |
oK guys we have torn down the motor to the bore and the block seems to be fine. there are no scratches or seison on it. the heads are fine as well no cracks or warping. turbo is fine, there was only a little bit of oil in it but from what I understand that seems to be normal and that is why Oil catch cans are sold am I correct? so rebuilding it should not be that bad. I already got a hold of another OEM piston for free so u guys think I can run that piston with new piston rings all arround while I save up more money to upgrade to forged? and if so how reliable si my car going to be? I will be getting a Metal head gasket as well.
-Juanitoe |
