Old 11-26-2005, 04:29 PM   #1
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
KA24E Exhaust Manifold. studs, washer, and nut.
Where can I get these? The ones I had are either rusted beyond repair, cracked, or missing.
These are the ones that go between the block, and the exhaust manifold. I believe there are 6 sets? or was it 4? I think it's 6.
I called Nissan, and they want like $4.00 a stud, $9.00 a bolt.
Are there any alternatives? I was thinking of just using a bolt with a washer. Instead of a stud?
Is there any places where I can get "aftermarket" studs and bolts? I looked at ARP and they're like $145 a set.
Any engine rebuilders can help me out? Hook me up?
95zilvia is offline   Reply With Quote
Old 11-26-2005, 04:31 PM   #2
95zilvia
Oh, and I think I have some of the part numbers for these studs and nuts.
Not sure if they're right, because the parts guy was tellin it to me rather quick.
14037
42L02
14064n4200
hope that'd help.
Old 11-26-2005, 04:33 PM   #3
40daws
40daws is an unknown quantity at this point
on my KA24E i did buy Nissan studs (you are not going to find them anywhere else, I tried .) As far as the bolts and washers, I bought mine from Toyota.Ask for Exhaust studs bolts for a 92-96 Corolla with a 1.6 or 1.8 liter and they bolt right up. Copper with washer and where $4.00 each i think.
40daws is offline   Reply With Quote
Old 11-26-2005, 06:08 PM   #4
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
Kragen, perhaps?
Call Courtesy Nissan, maybe theycan get you a better price.
If not, time to go to the junkyard
kazuo is offline   Reply With Quote
Old 11-26-2005, 06:37 PM   #5
95zilvia
Its hard to pull em out from the junkyard as well, because I have tried!
And it always smells like shit in those junkyards, I think people crap in the cars cuz they have no where else to go.
Any more suggestions? Courtesy Nissan, I will give them a call.
Old 11-26-2005, 09:12 PM   #6
projectRDM
projectRDM's Avatar
With a stud puller you can have them all out quick to hold your breath if the smell really is that bad.
FORMERLY R240NA
Old 11-27-2005, 01:24 AM   #7
haveblue
haveblue's Avatar
haveblue is an unknown quantity at this point
Send a message via AIM to haveblue
buy the nissan ones or something similar of grade 8 or better. cheap bolts will break off and then you are REALLY screwed. you also will want to put some antisieze or other compound to keep the bolts from seizing in there if you ever expect to take them out without breaking them off.
haveblue is offline   Reply With Quote
Old 11-27-2005, 04:58 AM   #8
95zilvia
I'm trying to avoid buying them from Nissan, it's gonna runme like $90 or something Makes me sad.
I'm just lookin into some options.
Old 11-27-2005, 05:03 AM   #9
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
go to sleep!
can't matt get them through nissan?
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 11-27-2005, 08:55 PM   #10
95zilvia
ITs chedddaaaa, no moneyz, buy em for me diddy
Old 11-27-2005, 08:59 PM   #11
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
Go to a hardware store, not homedepot, but an actual hardware store carrying strictly bolts and such.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 11-27-2005, 09:12 PM   #12
NemeGuero
No more nissan.
NemeGuero's Avatar
For bolts that important... find a part-out. Or go new. They're treated or tempered to withstand the abuse of being an exhaust manifold bolt. OEM or ARP. No hardware store bolts for engine related bolts.
Old 11-27-2005, 09:47 PM   #13
95zilvia
Yeah, otherwise I would of already went to OSH or Home Depotzzzz.
Old 11-28-2005, 02:33 AM   #14
DRFT
DRFT is making a name for him/her selfDRFT is making a name for him/her selfDRFT is making a name for him/her self
is there any way of removing broken studs?? besides dye and tap? my bolts are so old and brittle, that they snapped on me.
DRFT is offline   Reply With Quote
Old 11-28-2005, 03:00 AM   #15
NemeGuero
No more nissan.
NemeGuero's Avatar
you can make an edge in it, so you can turn it out with a screw driver.
get a dremel and cut a line across the bolt so you get a flat head groove.
Old 11-28-2005, 10:27 PM   #16
superman0234
superman0234 is an unknown quantity at this point
Send a message via AIM to superman0234
Not too possible when the bolt is snapped off inside the block.....
superman0234 is offline   Reply With Quote
Old 11-28-2005, 10:36 PM   #17
NemeGuero
No more nissan.
NemeGuero's Avatar
yah, you just have to use a different dremel bit. or a small drill bit
Old 11-28-2005, 11:04 PM   #18
95zilvia
The whole reason that it's stuck is that it's all fugged up probably.
If you weren't able to get it out using the head of the bolt still on it, then the stud is probably stuck in there pretty good.
I think I may have solved my problems, I was able to order the bolts for a cheaper price.
BUt for some reason, they source I am buying it from says the tops are bolts, while the bottoms are studs? I dont know anymore, I give up.
Old 11-28-2005, 11:50 PM   #19
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
Yes, that is the way that the car came stock, bolts on top, studs on bottom...
zero.counter is offline   Reply With Quote
Old 11-29-2005, 12:44 AM   #20
95zilvia
sweetness!
Old 11-29-2005, 02:04 AM   #21
kazuo
Wow, dude, like, buy a can of PB blaster and get some real tools.
Studs should not be hard at all to remove, I do it all day long at pick & pulls.
Old 11-29-2005, 03:33 AM   #22
95zilvia
I dont have a problem removing studs, it's just that I misplaced them :P
And then at the junkyard, all the friggin manifolds had either shitty hardware store bolts, or they're missing stuff.
I already ordered a new set.
Old 11-29-2005, 08:44 PM   #23
haveblue
haveblue's Avatar
you need to soak the bolts/studs in wd40/PB blaster/whatever
for removing studs/bolts broken off inside the head you have a few options:
1. e-z-out kit (may not be the real name) from sears. this is a reverse drill bit set that bites into the broken stud and spins it out. use some cutting oil for lubrication when drilling into the stud. if you break one of these off and get it stuck in the bolt, forget it. they are made of hardened steel and you will not be able to drill them out (see #3).
2. weld a piece onto the broken stud/bolt that you can then grip and remove.
3. drill out the bolt, re-tap it for a larger bolt. this usually requires a drill press and removal of the engine cause its real hard to drill a straight/perpendicular hole with a hand drill.
4. crazy expensive laser cutting removal. gota send the head out for this one.
5. new head.
