Old 11-29-2005, 12:27 AM   #1
Ricks15
Ricks15's Avatar
Ricks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud of
playing around with Octane levels on a stock KA
If you have a completly stock KA and if you start mixing certain octane levels will you currupt you're cars computer??? For example if you feed it 87octane gas for work and then by the end of the week youre going to go to screw around at the canyons or at the drag strip you put in 91 octane for those hi performace driving, then when you're going to put back the cheap 87 gas will you get any problems while doing this switching fo gas octane levels???? Because thats what I have been doing and my car has alot of problems when I drive it.
Ricks15 is offline   Reply With Quote
Old 11-29-2005, 12:29 AM   #2
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
No you wont mess up the car's ecu from mixing octanes.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 11-29-2005, 12:52 AM   #3
Ricks15
Ricks15's Avatar
well my car has been acting up latley when I make that transition from 87 to 91 then back 87 octane?
Old 11-29-2005, 01:09 AM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
you really don't need a higher octane for a stock internal, naturally aspirated KA. The higher octane is to prevent detonation, but its unlikely you will do that without beating the crap out of your KA with no regard for red lines.
Old 11-29-2005, 01:22 AM   #5
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
You can cause some problems with the O2 sensors when using extremely higher than normal octane levels.
Say for instance, shell octane 93, then adding some of that octane booster from NOS brand, which can raise octane levels from 1 to 4 points. Some of the cheaper O2 sensors have issues (universal ones) at least.
zero.counter is offline   Reply With Quote
Old 11-29-2005, 09:19 AM   #6
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
on a stock KA higher octane doesn't make much of a difference (hence switching around won't cause any problems). Some of us here are quite anal putting higher octane gas into the 240sx since on your gas door it says "premium gas for performance". This whole debate can go on for ever... so... it's all up to you.
I haven't touched 87 octane for a LONG time - I'd say put at least 89 octane for good performance/reliability even though our cars are made to run 87 octane - afterall the difference in money you spent on gas is NOT that significant.
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 11-29-2005, 10:18 AM   #7
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
i dont want to state this as a fact, but people have seen people state that a 91 octane will get better mpg than 89 or 87 octane gas. and they have done the calculations showing that they come REALLY close when averaging the cost per mile...
something to think about
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 11-29-2005, 11:21 AM   #8
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
if your engine is in good condition, 87 octane is fine. my friend with a freshly rebuilt sohc is beating the crap out it, and no problems.
if it's old however, you probably have quite a bit of carbon deposits on your pistons, but usually not enough to change your compression ratio that much.
and your engine problems are not related to your switching of octanes. it's all in your mind. your engine's fucking up for other reasons
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 11-29-2005, 11:29 AM   #9
aznpoopy
aznpoopy's Avatar
iirc sohc is supposed to use lower octane
they only started recommending premium on dohc ka24de's
take this as you will, because i don't remember where the hell i heard/read this from.
Old 11-29-2005, 02:37 PM   #10
pr240sx
pr240sx is an unknown quantity at this point
I was using 87 before going KAT.
At that time, I got better MPG with 87 than 89 or 91.
Now I am experimenting (and probably blowup my engine) going back to at least 89. Adding more fuel and retarding more timing.
My goal, run my KAT on 87 (and again, probably blew my engine) doing 8 psi of boost.
As of now, I am running 89 at 8 psi with the BTM with no problems thougt.
pr240sx is offline   Reply With Quote
Old 11-30-2005, 02:10 AM   #11
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
there's no reason to go beyond the recommanded octane rating. the reason is that your stock KA has the right stroke/compression and timing to burn 87. putting anything higher will do nothing for your stock setup.
now for cars that need premium octane, if the owner were to put lower octane. the ecu will know and retard the timing a bit. which the engine will not create the most power of its potential.
leaded gaslone is what damage O2 sensors, not octane rating. =)
driftingisgay.com
nrg is offline   Reply With Quote
Old 11-30-2005, 02:14 AM   #12
Nismo180
Nismo180's Avatar
Nismo180 is a well-known jackass
On a technicality you'll get more out of the lower octane, reason being lower octane gas burns a little faster, the retarded flame front speeds are half the reason higher octane works better in detenation prone events. Any tests you have read that state your motor will work better on higher octane were probably not performed in the most scientific of matters, the only "production" motors I know that can run on crap(comparatively) and get better performance off the good stuff are modern fuel injected bike motors. Most have 91 octane maps, but the ECU will detect higher octane fuel and run more timing etc. Your ECU doesn't do that. Get 87 and keep your money out of the gas companies pockets.
Nismo180 is offline   Reply With Quote
Old 11-30-2005, 06:22 AM   #13
xamS14
xamS14 is an unknown quantity at this point
Send a message via AIM to xamS14
now what if u are running 16 BTDC on your timing, instead of 20 BTDC (fatory). should i be putting 89 or 91 octane?
xamS14 is offline   Reply With Quote
Old 11-30-2005, 01:14 PM   #14
96240sxSE
96240sxSE is an unknown quantity at this point
Going from 20 BTDC to 16 BTDC is retarding the timing, which means that you can use LOWER octane fuel. It also kills power on an N/A motor, since there isn't any boost to replace the lost timing. Hence, there is no reason to retard timing on a stock motor ( unless you have problems handling all that "power").
96240sxSE is offline   Reply With Quote
Old 11-30-2005, 01:40 PM   #15
skatanic28
skatanic28's Avatar
skatanic28 is an unknown quantity at this point
Send a message via AIM to skatanic28
the existence of 2 seperate timing maps in the stock ecu programming leads me to believe that you will get slightly less performance using 87 octane if detonation problems are detected. if someone had a techtom/multichecker like device, this would be a fairly easy thing to check.
skatanic28 is offline   Reply With Quote
Old 11-30-2005, 03:00 PM   #16
ranisron
well, let me put it this way.
There's one Marathon gas station 15 miles away from my place that sells 93 octane for 10+ cents more than 87 octane (comparing to the usual 10c increase from 87-89 and another 10 cents increase from 89-93). Which one do I use? 93 octane. Gas in Martinsville is 10 cents cheaper than Bloomington, IN anyway.
It doesn't harm the car nor my pocket as long as I drive my car like a grandma during the day. BTW, I advanced my timing, too... so 89 at least.
U13 and S13
