Old 12-11-2005, 08:49 PM   #1
armand
armand's Avatar
armand is on a distinguished road
Send a message via AIM to armand Send a message via Yahoo to armand
SR fan hits crank pulley
i have a red top sr and my radiator fan hits mt crank pulley, i had to put some washers in between the fan clutch and the fan so it dosen't hit the crank pulley. i was just wondering if anyone else has ran into this problem. also i am useing the fan from my ka24e could that have something to do with it. i thought the ka and sr used the same fan.
armand is offline   Reply With Quote
Old 12-11-2005, 11:08 PM   #2
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
yea that has a lot to do with it...u cant use the KA fan on the SR. its bigger. ask 420xs..we ran into that prob when we did his swap.
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 12-12-2005, 04:49 AM   #3
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
yea the sohc fan hits. the dohc doesnt.
reccakun08 is offline   Reply With Quote
Old 12-12-2005, 09:50 AM   #4
armand
armand's Avatar
ok great thanks guys, so i will find me a sr fan or one fron a dohc ka
Old 12-12-2005, 10:36 AM   #5
armand
armand's Avatar
also i was wondering if the fan clutches are the some or do i need to find one from a sr
Old 12-13-2005, 12:14 AM   #6
reccakun08
reccakun08's Avatar
im not 100% sure but all i know is that when i tried to use the sohc ka clutch fan it didnt fit bc of the crank pulley. and the dohc ka clutch fan clears the pulley. i took a close look to see the difference in either sr,kade,kae clutch fan but the SR and KADE is what you probably need.
Old 12-18-2005, 03:09 PM   #7
Muzzy
Muzzy's Avatar
the dohc doesnt work either...unless we did somethin wrong
lemme have a dollar
Old 12-18-2005, 03:30 PM   #8
SoSideways
SoSideways's Avatar
I've compared the fans from a KA-DE and the SR, and you can tell that where the metal ring is on the clutch fan itself, on the SR, it's kinda got like a negative offset on it, whereas the KA-DE fan has like a 0 offset.
Because of that offset, when you go to put the fans on, the fan will either just clear the crank pulley or hit the crank pulley.
However, I think 1 of the motor's clutch unit for the clutch fan sticks out further and 1 of them is shorter, I can't remember. In either case, I must have the one that sticks out further, because I can use either the KA or the SR fans on my SR and they both cleared my crank pulley.
