Old 04-26-2002, 01:21 AM   #1
Powerzen2002
Powerzen2002 is an unknown quantity at this point
Send a message via ICQ to Powerzen2002
Ok.  Heres what I did, and cant figure this out.
My car has been feelin kinda jumpy since I put a fresh
pair of wires and plugs in my 240.
I used NGK V-plugs, and (temporarily till my NGK wires come), I bought these Super-Magcore or SuperMag Wires from Pepboys.
What is the possiblities for the car to mimic bad wires and plugs after I put fresh ones in?
Thanks again .
P.S.  The old plugs were aged normally, no abnormal discolor or wear.
No Quote, No Cares, Just Drive.
Powerzen2002 is offline   Reply With Quote
Old 04-26-2002, 10:38 AM   #2
sykikchimp
WOW addicted
sykikchimp's Avatar
did you make sure you put the plug wires on in the right order??  Also make sure that your got the plugs wire boots got seated good on the plugs.  They should "Snap" into place.
Old 04-26-2002, 11:58 AM   #3
xhdriver
xhdriver is an unknown quantity at this point
if that doesnt help then a new fuel filter might do the trick
xhdriver is offline   Reply With Quote
Old 05-01-2002, 03:20 AM   #4
9524tee
9524tee is an unknown quantity at this point
Send a message via AIM to 9524tee
time for a full rebuild
Nancy Kappa Monkey Squad
9524tee is offline   Reply With Quote
Old 05-03-2002, 07:12 AM   #5
S13drift
S13drift is an unknown quantity at this point
Check your motor mounts.  If they are gone that will cause a lack in acceleration too.  Mine were shot and the motor had a lot of play.  When I rev the engine the motor moved a lot to the point it was scary.
S13drift is offline   Reply With Quote
Old 05-03-2002, 07:16 AM   #6
S13drift
