Old 12-14-2005, 08:07 PM   #1
mandys13
mandys13 is an unknown quantity at this point
New here and need help
Hello my name is Amanda. I just picked up my first car it's pretty stock, but it is a 90 240sx with gp sport body kit, tein coilovers, magnaflow exhaust, act clutch, and 17" 5zigen fn01r rims. The problem I'm having is the car idles funny. It will dip and almost die but save itself occasionally. Most of the time I have to pop the clutch or restart it. I popped the hood to see if I could find out what was wrong because the guy who sold it to me said that the mas was bad. I looked at the mas, and coming from the same wire loom are 2 sensors or something that aren't plugged into anything. One of the plugs says SJD...I don't know what these are, or where they go, but I think that it might fix the idle problem. any input would help, thanks a lot.
I'll try to put up pictures tomoorow.
mandys13 is offline   Reply With Quote
Old 12-14-2005, 08:49 PM   #2
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
sounds like that guy said MAF not MAS, but thats just me
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 12-14-2005, 08:56 PM   #3
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
What you are describing sounds like what my s13 did when the MAF was killed by my K&N filter oil on my shiny new intake system...i pwned myself in that case w/my n00bness
wait,amanda!!! sweet another chick on the boards
Last edited by Ghettokracker71; 12-14-2005 at 08:57 PM.. Reason: Fucking apple laptop
Ghettokracker71 is offline   Reply With Quote
Old 12-14-2005, 10:03 PM   #4
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
a stock S13 MAF should be pretty east to come by seeing as eceryone switches them out when they go SR with somehting a bit better. look in the FS section, or post a WTB thread. never know may luck out and find someone local that you can pick it up off of for cheap/free
Tenchuu is offline   Reply With Quote
Old 12-14-2005, 10:59 PM   #5
beetlejuice
beetlejuice's Avatar
beetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura about
1) Mass Air Flow Sensor (MAFS) could be the culprit. Check voltage on MAFS and replace if needed.
2) Idle Air Control Valve (IACV) could be the culprit (on back of intake manifold, between manifold and firewall). Remove and clean with carb cleaner or replace.
3) Bad grounds in the engine wiring harness could be the culprit. Trace harness and rewire or replace.
Download a copy of the Factory Service Manual (FSM) at zeroyon.com if you haven't already.
Good luck
jollydwarf.com
beetlejuice is offline   Reply With Quote
Old 12-14-2005, 11:10 PM   #6
YakuzaS14
YakuzaS14 is on a distinguished road
u might have a vacuum leak. actually i had the same problem in my s13 and it ended up being a vacuum leak so check ur hoses carefully for cracks before u start trowing parts at it.
YakuzaS14 is offline   Reply With Quote
Old 12-14-2005, 11:25 PM   #7
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
Ya sounds more like a vac leak.
PS - Post pics. kthx.
kazuo is offline   Reply With Quote
Old 12-15-2005, 01:03 AM   #8
S13SilviaGirl
UGH Really?
S13SilviaGirl's Avatar
S13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfection
Get off her already! haha
welcome to the boards, ur car dosnt sound that stock. Ignor the drooling guys and pic requests, and enjoy zilvia.
My Review Thread
Originally Posted by DTCSuperstar
I surf Zilvia naked in my home...
S13SilviaGirl is offline   Reply With Quote
Old 12-15-2005, 03:48 AM   #9
Nan Desu Ka?!
Nan Desu Ka?!'s Avatar
Nan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to all
Send a message via AIM to Nan Desu Ka?!
maybe he wanted pics of the car?....
just a thought. :P
+3 for vacuum leak. check your hoses, same thing was happening to me. replaced a few worn/cracked hoses and everything is tip top now.
oh and welcome to zilvia.
Norcal-240sx.net
Nan Desu Ka?! is offline   Reply With Quote
Old 12-15-2005, 04:26 AM   #10
NemeGuero
No more nissan.
NemeGuero's Avatar
Haha, yah.. pretty sure he meant pics of her unconnected sensors. I'm curious to see what she's talking about as well.
I too think its a vacuum leak. Do you hear any hissing with the engine running?
BTW: Welcome to Zilvia.
Old 12-15-2005, 05:03 AM   #11
andrewmp6
andrewmp6 can only hope to improve
yeah welcome to zilvia its probably the maf its on the intake right after the air filter has a wire pluged in it
andrewmp6 is offline   Reply With Quote
Old 12-15-2005, 11:39 AM   #12
i8yourfwd
i8yourfwd's Avatar
i8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfection
Send a message via AIM to i8yourfwd
hahha... one of the nicest welcome threads i've seen on zilvia in a while...
http://jaythroughglass.blogspot.com
S13SilviaGirl: Mel are you that big?
i8yourfwd is offline   Reply With Quote
Old 12-15-2005, 12:16 PM   #13
Nan Desu Ka?!
I think it's becuase...
1. She did not mention SR, JDM, "i have a LHD 180sx". or "how do i doooorrrifto on the streets!!1one"
2. She asked a specific question.
3. She did not speak in AOLese.
Norcal-240sx.net
Old 12-15-2005, 12:30 PM   #14
NemeGuero
No more nissan.
NemeGuero's Avatar
Word, proper forum etiquette demands respect.
Old 12-15-2005, 12:35 PM   #15
i8yourfwd
i8yourfwd's Avatar
Word.
Anyways... I had real bad idle problems, all I did was take the MAF connector, blew some air in it to clean it out, plugged it back in. Fixed the idle problem. Funny thing is, it fixed my friend's idle problem also when we did it to his car.
Old 12-15-2005, 02:02 PM   #16
Gnnr
Gnnr's Avatar
Originally Posted by i8yourfwd
Word.
Had the same experience with MAF. Those pins like to be clean.
Gnnr is offline   Reply With Quote
Old 12-15-2005, 05:37 PM   #17
mandys13
Alright here it is...
Tell me what you think about it, or if you have any suggestions, sorry forgot to bring the problem pictures, I'll post them in just a minute.
Old 12-15-2005, 05:46 PM   #18
infinitexsound
funny thing is that car just doesnt look right, i mean if i was in the car it would... u could be my navigator........ !! cool car, need some lower offset wheels and a tad bit lower... and then YOUD ROCK GIRL!
Old 12-15-2005, 05:50 PM   #19
Irukandji
I had the same problem with my car.
Replace your cap and rotor (on distributor). Before you start spending doh on aftermarket crap, do a full tune up on our car. i.e. Sparkplugs, sparkplug wires, cap, rotor, air filter, clean out throttle body, flush out radiator, bleed brakes+clutch etc etc
Old 12-15-2005, 06:09 PM   #20
S13SilviaGirl
UGH Really?
yepp yepp, nice car, and welcome! Hopefully the guys can help you fix your problem.
My Review Thread
Old 12-15-2005, 06:29 PM   #21
mandys13
Here is my problem...
I'm going right now to go get a new mas, but if anyone knows where these plug in please help me out, thanks a lot!
Old 12-15-2005, 06:43 PM   #22
NemeGuero
No more nissan.
NemeGuero's Avatar
Damn, its hard to tell from those pics.. but that looks like some hacked up wiring to me.
I'd compare with any other 240s in your area to see correctly where everything goes. That last plug looked like the CAS for the distributor.. but like I said, its kinda hard to tell.
Old 12-15-2005, 07:51 PM   #23
infinitexsound
yeah looks like the plug for the cam angle sensor(cas), u might wanna check out the MAF (not mas) tho check the pins , if its dirty that might be ur problem...stupid connections i tell u... anyways ur hand should be dirty not clean.... please clean up that engine bay seriously it looks horrid..
Old 12-15-2005, 07:56 PM   #24
NemeGuero
No more nissan.
NemeGuero's Avatar
In fact, that looks like a really old, if not wrong, distributor...
Mine looks nothing like that design/shape.. which would explain why some connectors aren't connected?
Old 12-15-2005, 08:04 PM   #25
infinitexsound
thats the thing with swaps......... i dont know the past history with that car... but stating this as the situation... started as a sohc, guy dropped in a de but had a s14 ka harness but had a s13 de dizzy.. that could be it... tomorrow when theres light outside ill pop my hood and check out the front harness for yah and let yah know what goes to what...
Old 12-15-2005, 09:50 PM   #26
mandys13
The guy who sold me the car said that he did a new motor put in about 40k ago and that's all he told me about it, so I don't know, you might be right. If you could check that out tomorrow, let me know, I would appreciate it a lot.
And thanks everyone for the help and input, if you have anything else you think would help, please let me know.
Old 12-15-2005, 09:52 PM   #27
NemeGuero
No more nissan.
NemeGuero's Avatar
Can you call him and ask him?
It'd make trouble shooting a lot easier if we knew the wiring harness that's in the car, the distributor in the car, etc..
Old 12-15-2005, 09:57 PM   #28
mandys13
Yeah I'll give him a call tomorrow and then let you guys know what he said.
Old 12-15-2005, 10:26 PM   #29
Ghettokracker71
whoaoo check out those girl hands
Just kidding:-D . The car looks great in the pics,need some sidemarkers though! Personally I went with the ML320 sidemarkers,so fucking bright and easy. Anyway,welcome to the board. Hmm.hissing sound means vaccume leak,eh? My 240 started making a really loud hissing since I put the intake on when I turn the motor off,and theres a really slight hiss when its running...hmm...
Old 12-15-2005, 10:54 PM   #30
S14DB
AFC #1
S14DB's Avatar
Yeah, That harness has been hacked up. Looks like a bad SOHC to DOHC swap. You ether need to grab a 91+ FSM and start tracing wires or get a DOHC harness.
