Old 12-28-2005, 03:50 PM   #1
JohnJunYi
JohnJunYi's Avatar
JohnJunYi has made poor choicesJohnJunYi has made poor choicesJohnJunYi has made poor choicesJohnJunYi has made poor choicesJohnJunYi has made poor choicesJohnJunYi has made poor choices
Send a message via AIM to JohnJunYi
Back lights?
Iam having a problem with my back lights, at night when i put my lights on the back lights dont turn on. By breaklights work,reverse lights, but not just the normal lights in the back when i have my lights on. Could this be a fuse problem, or bulb problem. I went to shucks and they said that the lights is only powered by one fuse so it would be the bulb but my friends say other wise. just need some imput from s14 owners. thanks
JohnJunYi is offline   Reply With Quote
Old 12-28-2005, 03:54 PM   #2
projectRDM
projectRDM's Avatar
You don't really need input from an S14 owner, as all cars have rear parking lamps. Ours are no different.
If the brake lamps work and the rest of the parking lamps do as well then the bulbs are bad. If all the parking lamps are out then it's a fuse.
FORMERLY R240NA
Old 12-28-2005, 06:43 PM   #3
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
that is not true, the voltage source from for the parking lamps is the multi function switch while the the brake lamp source is the brake switch. The bulbs are dual fillament.
RedtopTech is offline   Reply With Quote
Old 12-28-2005, 07:16 PM   #4
projectRDM
projectRDM's Avatar
Good job fuckwad, I just said that. A dual filament bulb can still burn out on only one filament, meaning the bulb is still bad. One side works, the other side doesn't. Bad bulb. No other way to look at it sparky.
FORMERLY R240NA
Old 12-28-2005, 10:11 PM   #5
Armysweitzer
Armysweitzer is an unknown quantity at this point
Send a message via AIM to Armysweitzer
i have the same problem, keep blowing fuses. Checked all the bulbs, wiring etc..
My life is simple, my food is plain, and my quarters are uncluttered. In all things, I have sought clarity. I face the troubles and problems of life and death willingly. Virtue, integrity and courage are my priorities. I can be approached, but never pushed; befriended but never coerced; killed but never shamed.
- Yi Sunshin
Armysweitzer is offline   Reply With Quote
