Old 05-01-2002, 05:32 PM   #1
bc240sx
bc240sx is an unknown quantity at this point
Does any body knows if i upgrade my brake to Z32 caliaper will my stock S14 16" SE will it fit, or do i have to put on some kind of spacer H&R Spacer , if i do .. what the size i should get 5mm or 15mm??
95 240sx Pearl White.. Bomex Rules...!!!!!
bc240sx is offline   Reply With Quote
Old 05-01-2002, 05:52 PM   #2
s15dude
s15dude is an unknown quantity at this point
Send a message via AIM to s15dude
The stock S14 SE wheel will fit.
s15dude is offline   Reply With Quote
Old 05-01-2002, 09:27 PM   #3
bc240sx
Great Great.. thx
Old 05-01-2002, 09:29 PM   #4
bc240sx
Great Great.. thx
Old 05-01-2002, 11:47 PM   #5
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
wait, iirc there are two rotor sizes, 26mm for the n/a and 30mm for the tt. Correct me if I'm wrong, but I don't think the larger setup will work
Rowsdower saves us and saves all the world!
misnomer is offline   Reply With Quote
Old 05-02-2002, 12:25 AM   #6
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (misnomer @ May 02 2002,12:47)</td></tr><tr><td id="QUOTE">wait, iirc there are two rotor sizes, 26mm for the n/a and 30mm for the tt. Correct me if I'm wrong, but I don't think the larger setup will work</td></tr></table><span id='postcolor'>
ok i will correct you
the s14 rims will clear any z32 brakes 26mm or 30mm i have the 30mm iron calipers and oem rotors on my car and it clears just fine
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 05-02-2002, 09:29 AM   #7
bc240sx
Great , thx for all u guys reply ... also is the Z32 &nbsp;brake up grade will make that much diff in braking ? cause i do go track alot and now my brake sux really bad even tho i have brembo rotor front and back, and with PBR brake pad , still doesnt; do any good ... so what should i do .. reallly go with Z32 brake up grade or what ??
Old 05-02-2002, 09:54 AM   #8
BlackFox
BlackFox is an unknown quantity at this point
All you need is the Brembo big brake kit, yeah, i know it costs $3k but I'm getting my business license so I can get it for much less, not sure the exact number yet, but I'll post something up when I get it set up.
13" rotors
3cm wide rotors
4 piston caliper
cross drilled and slotted
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Current Cars:
1976 Mercedes Benz 300D
1995 240sx SE aka Kate (winner: Best Stock S14 @ 2002 National Convention)
http://community.webshots.com/user/jeff976cal
If you're interested in parts email me
[email protected]
BlackFox is offline   Reply With Quote
Old 05-02-2002, 10:50 AM   #9
camppain
camppain's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (bc240sx @ May 02 2002,10:29)</td></tr><tr><td id="QUOTE">Great , thx for all u guys reply ... also is the Z32 brake up grade will make that much diff in braking ? cause i do go track alot and now my brake sux really bad even tho i have brembo rotor front and back, and with PBR brake pad , still doesnt; do any good ... so what should i do .. reallly go with Z32 brake up grade or what ??</td></tr></table><span id='postcolor'>
yes it can be felt and is a very good upgrade imho.
you will feel a lil mushyness for the first 1/2 inch or so of pedal travel. overall its a reall good braking setup.
and as far as brembro brakes for 3k?! pah!i did my whole swap for
50 a caliper rebuilt
100 for 2 stock oem rotors
32 for oem pads
90 for 4 steel lines
around 21 bucks for misc items like pins and shims
so even if you can get it less than 3k like 2 k i think its a waste unless your a serious serious auto x or sponsered.
or just rich up the ass
Old 05-02-2002, 11:47 AM   #10
Tyler Durdan
Tyler Durdan's Avatar
Tyler Durdan is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (camppain @ May 01 2002,02:25)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (misnomer @ May 02 2002,12:47)</td></tr><tr><td id="QUOTE">wait, iirc there are two rotor sizes, 26mm for the n/a and 30mm for the tt. Correct me if I'm wrong, but I don't think the larger setup will work</td></tr></table><span id='postcolor'>
the s14 rims will clear any z32 brakes 26mm or 30mm i have the 30mm iron calipers and oem rotors on my car and it clears just fine</td></tr></table><span id='postcolor'>
Where is a good online site to pickup the z32 30mm irop calipers, and the oem rotors? &nbsp;Also, how much should I expect to pay for the whole set up including the steel braided brake lines? &nbsp;Thanks for the help in advance.
&quot;Pure adrenaline attached to a license plate. &nbsp;Isn't it time to experience one yourself?&quot; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; -Dan Gurney
Turbo for Sale
Tyler Durdan is offline   Reply With Quote
Old 05-02-2002, 01:25 PM   #11
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
Funny - I go to the track w/ stock calipers and OEM rotors and have no problems whatsoever.
Maybe it's your fluid. &nbsp;What kind of pads are those? &nbsp;
I use CarboTech Panther+ pads and ATE SuperBlue fluid. &nbsp;The only time I had any problems was the first time when I was using Wilwood fluid - that stuff sucks! &nbsp;It boiled and I lost pedal feel at the end of the day.
HippoSleek is offline   Reply With Quote
Old 05-02-2002, 09:17 PM   #12
camppain
camppain's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Tyler Durdan @ May 03 2002,12:47)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (camppain @ May 01 2002,02:25)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (misnomer @ May 02 2002,12:47)</td></tr><tr><td id="QUOTE">wait, iirc there are two rotor sizes, 26mm for the n/a and 30mm for the tt. Correct me if I'm wrong, but I don't think the larger setup will work</td></tr></table><span id='postcolor'>
Where is a good online site to pickup the z32 30mm irop calipers, and the oem rotors? Also, how much should I expect to pay for the whole set up including the steel braided brake lines? Thanks for the help in advance.</td></tr></table><span id='postcolor'>
i bought my calipers from autozone for 50 bucks already rebuil;t thrwew my 240s in as a core
yu can get iron or the aluminum depends on what u want.
lines you can get from projectsilvia.com pdm-racing.com and others not to sure thoughi bought oem pads and rotors from my job cause i work at a nissan dealer.
there is more info on this in archives and faq's
