Old 12-29-2005, 09:18 PM   #1
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
wtf, oil pool in turbo inlet?
I take off my rubber intake pipe today to get to some rust in need to fix below the master cylinder... too my surprise i find a small pool of oil sitting in the inlet-elbow. I just put on a greddy catch can, so i have no idea where its coming from... i even added the steel wool, and a pipe inside to keep the crap from being sucked back into the intake. maybe just old turbo seals?
any ideas on this is coming from? i'll have pictures up in a few minutes
thanks
edit:
nsn240 is offline   Reply With Quote
Old 03-09-2006, 11:58 AM   #2
AuburnRyan
AuburnRyan is an unknown quantity at this point
Bump - curious...
I also replaced my intake last night, only to notice "muddy" soot (thin oil) around intake piece and turbo inlet. I have the stock Catch.
'93 Fastback LE - Wrecked
'91 Fastback HICAS and LSD - Sold
'93 Fastback SE - Current
AuburnRyan is offline   Reply With Quote
Old 03-09-2006, 12:33 PM   #3
CHARLIE2020
CHARLIE2020 is an unknown quantity at this point
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
A dirty/clogged air filter will cause that sort of problems, atleast thats is a cause for that.
CHARLIE2020 is offline   Reply With Quote
Old 03-09-2006, 12:34 PM   #4
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
How did you install your catch can? Did you remove the oil seperator from the back of the valve cover?
The catch can should go between the line that used to run directly to the intake.
lok is offline   Reply With Quote
Old 03-09-2006, 02:15 PM   #5
AuburnRyan
Well for me (OEM catch), the line from the valve cover runs straight to the intake. Seperate line form T runs to the catch
Old 03-09-2006, 02:26 PM   #6
lok
lok's Avatar
edit: nevermind
just check out this guys install explains how everything should go.
http://www.nissansilvia.com/forums/l...hp/t29690.html
Old 03-09-2006, 02:38 PM   #7
nsn240
nsn240's Avatar
wow, this is old haha
i think the reason for mine being so bad is either bad seals+cold weather and/or the way i have the return line setup
Old 03-09-2006, 02:52 PM   #8
lok
lok's Avatar
lol didnt even check the date.
Old 03-09-2006, 02:58 PM   #9
AuburnRyan
I chose your thread because you had good pics and valid question...so I'm getting that a stock SR will have this issue since the hose runs direct form cover to intake, like mine does?
