Old 01-10-2006, 04:30 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
is there difference between z32 and z33 brake swaps?
i currently have z32 26mm brakes and was wondering if the z33 brembos were bolt on just like the z32's?
will the same brake line work?
do i just replace the caliper and rotors again?
any info would be greatly appreciated
thanks
devon
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 01-10-2006, 06:04 PM   #2
Flybert
For z33 brembos you need to drill out your spindle brake bolt holes larger for the larger bolts that the brembos used. Pretty simple.
Old 01-10-2006, 08:50 PM   #3
projectRDM
projectRDM's Avatar
Z32 uses 12mm bolts, Z33 uses 14mm. Use a 9/16" drill bit and you're good.
FORMERLY R240NA
Old 01-11-2006, 12:36 AM   #4
andrewmp6
andrewmp6 can only hope to improve
with a lil work they should only thing i seen different between the two was the r32 uses a thicker rotor i believe id just get the z32 30mm save some time and easyer to get pads and rotors if you need one today
andrewmp6 is offline   Reply With Quote
Old 01-11-2006, 03:18 AM   #5
projectRDM
projectRDM's Avatar
Not to be a jerk, but could you at least go back to high school and learn how to use punctuation? Reading your posts is like trying to decipher hieroglyphics written by a retarded kid.
FORMERLY R240NA
Old 01-11-2006, 11:20 AM   #6
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
i was wondering the same thing. keep the useful/helpful information coming. does anyone have any pics of it?
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
