Old 01-14-2006, 10:04 PM   #1
Metal Monkey
Metal Monkey is an unknown quantity at this point
Noob here with a question
Hey guys I'm picking up a 180sx from calli in three but I got this question to ask you. I found a sr20de from one of my friend who is selling to me but how hard is it to turbo it and what do I need also can I put some sr20det parts on the sr20de. Any help will do also what is the compression on the sr20de.
Metal Monkey is offline
Old 01-14-2006, 10:56 PM   #2
Nan Desu Ka?!
Nan Desu Ka?!'s Avatar
Nan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to all
Send a message via AIM to Nan Desu Ka?!
Since you are thinking of swapping in a USDM SR20DE into your "180sx" I'm guessing you are not really getting a JDM 180sx, but rather that you think you will impress us by using "180sx" instead of the proper name, 240sx.
Your questions can be EASILY answered by doing a simple 1 word search. It would be in your best intrest if you use the search butotn in the future. Since you are a noobie, Ill get you going in the right direction:
LOTS of threads to pick through
http://www.zilvia.net/f/search.php?searchid=604355
Just 2 of the posts on the first of many pages that will probably answer a lot of the questions you have:
http://www.zilvia.net/f/showthread.p...ghlight=SR20DE
EDIT: found another one... SAME scenario as you, and 2 pages of info:
Next time, please search before posting something that has been discussed MANY times before.
Welcome to Zilvia.
Norcal-240sx.net
Nan Desu Ka?! is offline
Old 01-14-2006, 11:31 PM   #3
Metal Monkey
Welcome to Zilvia.
Thanks bro and sorry bouth the confusion. It's really a 240sx converted to a 180sx but the guy in calli said 180sx.
Old 01-14-2006, 11:57 PM   #4
andrewmp6
andrewmp6 can only hope to improve
its still a 240sx no matter what you do to it and turbing a sr20de is a pain cheaper and easyer to buy a sr20det
andrewmp6 is offline
Old 01-15-2006, 12:25 AM   #5
aznpoopy
aznpoopy's Avatar
an sr20de is NOT the same thing as a sr20det
an sr20de with sr20det turbo parts slapped on it is still not the same thing as a sr20det.
i think you need to do a little research on differences between the two engines. compression is higher on the sr20de then on the sr20det, as you would expect.
aznpoopy is offline
Old 01-15-2006, 03:39 AM   #6
!Zar!
!Zar!'s Avatar
Why are you purchacing a car and the first thing you worry about before you even purchace it is a swap? Being a nub is no excuse for stupidity. EVEN IF you get a sr20de it's not even close to a sr20det.
The DET has oil squirter piston coolers
The DET has a bigger oil pump.
The DET has a different front pulley.
The DET has lower compression pistons (8.3:1 vs 9.5:1).
The DET has bigger injectors.
The DET has direct ignition.
The DET has a variable intake cam, runs retarded at idle, advanced mid range and retarded top end.
The DET has mechanical shim in bucket type lifters with a slightly bigger in duration exhaust cam.
!Zar! is offline
Old 01-15-2006, 04:17 AM   #7
Nan Desu Ka?!
Well put, Mel. In all honesty you would yeild better results with less pain by going KA-T. If you want SR and you want it boosted, just get a damn SR20DET. If you wanna boost a NA motor, boost the KA. Done and Done.
SR20DE does NOT = SR20DET, as stated above. no mater what you do to it.
Norcal-240sx.net
Old 01-15-2006, 08:10 AM   #8
g6civcx
g6civcx's Avatar
What does the seller mean by calling it a 180SX?
g6civcx is offline
Old 01-15-2006, 08:18 AM   #9
IES13
IES13's Avatar
IES13 is making a name for him/her selfIES13 is making a name for him/her self
This is a real 180sx...
IES13 is offline
Old 01-15-2006, 12:32 PM   #10
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
he thinks hes in japan
you can do the sr20de and put on a turbo, it is the same setup i have, its cheaper than a sr20det... but it has plenty of disadvantages. you really need to search on this shit
nsn240 is offline
Old 01-15-2006, 12:51 PM   #11
Phlip
Yes, I look like that
Phlip's Avatar
Questions answered, flames unnecessary, please make sure to search before asking such questions moving forward.
Weirdo
And I write too!
Phlip is offline
