Old 01-15-2006, 01:46 PM   #1
sr_sil80
sr_sil80 is an unknown quantity at this point
Thumbs up PowerSlot Rotors with Axxis Ultimate Ceramic Pads?
I initially got a set of new Axxis Ultimate Brake Pads for my Skyline R32/Nissan Z32 brake conversion with the intention of getting Brembo or other metal aftermarket rotors.
I ended up buying Power Slot
Rotors...does anyone know if it's okay to run the ceramic blend Ultimate brake pads, or should I get Metal ones such as the Axxis Metal Masters, or Hawk brake pads as Powerslot recommends?
Any info will help....I would really like to use the Ultimates, unless if it'll affect the performance.
Thanks!
sr_sil80 is offline   Reply With Quote
Old 01-15-2006, 03:33 PM   #2
S14DB
AFC #1
S14DB's Avatar
Power Slot makes Ceramic Rotors? Link?
Old 01-15-2006, 04:22 PM   #3
sr_sil80
Haha, oops....got it mixed up w/ Cadmium.
Will the ultimate brake pads be cool w/ these rotors???
Old 01-15-2006, 04:53 PM   #4
iMAGE976's Avatar
iMAGE976 is making a name for him/her selfiMAGE976 is making a name for him/her self
Send a message via AIM to iMAGE976
shouldn't be to big of a deal....from past experiences i've ran X-Drilled and slotted rotors on regular brakes and metal ones and they seem to run fine. the only thing about it is it eats up the regular brakes a lot faster than the metal compound ones.but i always recomend wat the manufacturer says because they kno their product best...hope that helps. good luck with that BTW
iMAGE976 is offline   Reply With Quote
Old 01-15-2006, 05:16 PM   #5
S14DB
AFC #1
S14DB's Avatar
The Cadmium is a anti-rust coating. It's gone off the braking surface before you finish bedding the pads. You can use any pad with them.
