Old 05-05-2002, 12:19 AM   #1
gmgs14
gmgs14 is an unknown quantity at this point
Call me stupid but I can't seem to find the place to hook up the solenoid for my new oil pressure gauge.  If anyone can help that'd be great.
gmgs14 is offline   Reply With Quote
Old 05-05-2002, 02:44 PM   #2
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
i've never done one nor have i seen one but i would figure it would go somewhere near your oil pressure switch. its above/neaar your oil filter a 27mm scket fits into it.
again ive never seen how to install an oil pressure gauge but it should work off of the factory switch
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 05-05-2002, 03:35 PM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (camppain @ May 05 2002,4:44)</td></tr><tr><td id="QUOTE">i've never done one nor have i seen one but i would figure it would go somewhere near your oil pressure switch. its above/neaar your oil filter a 27mm scket fits into it.
again ive never seen how to install an oil pressure gauge but it should work off of the factory switch</td></tr></table><span id='postcolor'>
I'm not sure how it works myself, but is it possible to "T" off the Oil pressure line?
Old 05-05-2002, 08:00 PM   #4
Joe_M
Joe_M is an unknown quantity at this point
Send a message via AIM to Joe_M
easiest way to do it is to run -4AN stainless line into the block, then put a T at the end of it. &nbsp;Run the Autometer sender into one side, and the stock sender on the other. &nbsp;Zip tie the mofo to the firewall, paint it flat black, and hook it up as normal. &nbsp;That way the stock idiot light works, and your new gauge works too. &nbsp;Also it will keep the sender from vibrating off the block and snapping the sender in the block and spillling oil all over the place, which equals, a locked up motor. &nbsp;Old Honda trick <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> &nbsp;if you need any other help, I have diagrams.
Joe
1991 240SX LE Fastback SOLD!!
1992 USDM OneVia CA18DET powered SOLD!!
1996 240SX Base Model Rockin' the 4 Lug
1995 240SX Base Model $400 project car... and it runs!
Joe_M is offline   Reply With Quote
Old 05-05-2002, 09:28 PM   #5
Jeff240sx
I hate you too...
Jeff240sx's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sykikchimp @ May 05 2002,6:35)</td></tr><tr><td id="QUOTE">I'm not sure how it works myself, but is it possible to "T" off the Oil pressure line?</td></tr></table><span id='postcolor'>
But... the oil feed line to your turbo is T'd off the oil sending unit.
-Jeff
Whatup?
Old 05-05-2002, 10:27 PM   #6
gmgs14
Alright, I need some more help. &nbsp;Today I installed my gauges in my dash and my air fuel works fine. &nbsp;The problem is with the oil pressure. &nbsp;I took off the stock sender that goes to the dash light but the autometer sender wouldn't fit cos there is a bracket in it's way. &nbsp;I don't really want to cut this so maybe you could help me out a little more Joe_M. &nbsp;I really want this thing to work.
Old 05-06-2002, 12:58 PM   #7
sykikchimp
WOW addicted
sykikchimp's Avatar
I know you can buy an aftermarket oil filter sandwich that has a feed, and return line. &nbsp;Just run a ~2-3" hose between the two, and T off that hose for your oil feed line. &nbsp;OR.. &nbsp;you could get a remote filter mount and t off that, OR I think you could do the same thing with an aftermarket Oil cooler.. &nbsp;which you might want anyway, If your gonna run a turbo.
