Old 01-20-2006, 07:23 AM   #1
RYS13
RYS13's Avatar
RYS13 is an unknown quantity at this point
Inverted tude vs. Non-inverted
What are the advantages and drawbacks of having an inverted tube design on coilovers over non-inverted tubes?
RYS13 is offline   Reply With Quote
Old 01-20-2006, 07:36 AM   #2
DrtyRat
DrtyRat's Avatar
DrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfection
http://www.zilvia.net/f/showthread.p...n-inverted...a little info for you...hope it helps, if not just im some of the guys in the thread..gl
DrtyRat is offline   Reply With Quote
Old 01-20-2006, 07:43 AM   #3
g6civcx
g6civcx's Avatar
Advantages as claimed by the different manufacturers:
* more horizontal stability for suspension
* more overall stability and feel for driver
Real-world drawbacks:
* higher cost
* poor design, some inverted shocks actually have less stability than upright ones
* higher failure rate, some may not be as reliable under extreme track use
If you have the money for it, go for it. Just make sure you address some of the drawbacks before you invest.
Old 01-20-2006, 08:33 AM   #4
RYS13
RYS13's Avatar
Appreciate the feedback. Thanx guys.
