i wanted stock funcionality, where as most of the installs ive read about have the fans wired to turn on high with the car, which wastes power, shortens the life span of the fans, etc
this would make a nice sticky maybe? now i have a diagram to post up of exactly what i did here's the stock diagram, taken from the FSM i believe ( used the chiltons, its simpler, also, my diagram is based off the chiltons) ![]() and this is the modified one ![]() i tapped two 30A relays, one each into the stock relays, to control the power to the 2nd fan. i ran power from the terminal inside the fuse box in the engine bay to those relays, then out to the 2nd fan ![]() ![]() then i ran the two new power wires out to the 2nd fan, made a notch in one of the covers for the stock harness, put the wires through there ![]() I ran the ground wires to the battery but it's not neccessary, since you can ground them to the chassis anywhere or in my case, run them to one of the aftermarket ground wire connections on the motor 1st fan gets plugged into the stock plug ![]() 2nd fan gets wired to the two newly installed relays, the green wires are the power wires i believe ![]() you have to pop out the stock relays, which is kidna a PITA, but its all fairly simple Thanks to my buddy Paul (adikt on the forums) for figuring out the wiring for this, and helping with the wiring, as well as Konrad (shift knob, not on NICO i think) for pics and arguing about this ![]() |
from the look of the diagrams is your car an s14?
the only fan control on the s13 is the ac fan, which turns on at too high of a temp. None the less a temp controll sensor can be submitted for the ecu and all should be good. I like it. Nice and basic as things should be. |
![]() Join Date: Sep 2004
![]() ![]() ![]() Feedback Score: 0 reviews
the stock s13 ac fan is plenty for my sr w/ koyo. I was actually really surprised how much air it moved... and the Koyo has mounting points for this fan for an oem-like fit. wired up a variable t-stat switch to a new relay that sees voltage from the brown O2 heater wire (ignition on)... works perty good. heatshrink tubing & aircraft grade splices are yr friend
most of the pain in the wiring is how to use the dual speed function fo the Alti fans.
I have mine basically like yours, but I have an S-13. One circuit is connected to the AC, via a relay (30 amps) The other one is connected to a adjustable thermistor (@ 180) via a 30 amps relay. Why 30 amps, your are moving 2 fans Wire gauge is also critical, you CANT use gauge lower than 12 (thinner) or you run the chance of melting something. Also use a god ground for both circuits. My setup turn the fans on at 180F till 170F (via techtom) at single speed. If I am using the AC the fans also turns on (just like ECU) If both criteria met (AC and thermistor) the fans go into high speed. Also, if the ECU "sees" more than 212F it will activate (via AC relay) then the thermistor will also "sense" the temp over 180 so they will switch to high speed. Keep in mind that the ECU shut the fan off while using the AC at speeds over 25 mph, or if the AC temp control shuts down the compressor |
