Old 01-22-2006, 01:45 AM   #1
iamwesley
iamwesley is an unknown quantity at this point
PS banjo bolt
Where can I get one with washers?
iamwesley is offline   Reply With Quote
Old 01-22-2006, 01:52 AM   #2
aznpoopy
aznpoopy's Avatar
junkyard.
nissan dealer.
if you have the bolt, just buy the washers seperately from the dealer.
Old 01-22-2006, 02:16 AM   #3
IAM_SO_sLOw
IAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choices
Send a message via AIM to IAM_SO_sLOw
i say just go to a junkyard and pocket it lol
IAM_SO_sLOw is offline   Reply With Quote
Old 01-22-2006, 02:39 AM   #4
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
you can get them at autoparts stores cost. cost is low and its brand new.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 01-22-2006, 02:42 AM   #5
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
i believe the dealer charges $60 for the bolt alone and a stuipid dumb amount for the washers which you could get from home depot. i remember asking for two bolts for the pump and misc. nothings and they charged $180...
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 01-22-2006, 04:36 AM   #6
Suk02Si
Suk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfection
For which motor? The mount for the dohc was diff than the one for th SR
The one off my SR (left) has a slight angle to it. I have the stock dohc one (right) if you need it.
Suk02Si is offline   Reply With Quote
Old 01-22-2006, 09:18 AM   #7
kingsol
they both work with the sr pump
-Emerson
Old 01-22-2006, 09:19 PM   #8
sidious141
sidious141 is an unknown quantity at this point
2nd that, just make shure you hide it well
sidious141 is offline   Reply With Quote
Old 01-23-2006, 04:07 AM   #9
FRpilot
FRpilot's Avatar
Post
aren't the washers thin copper washers? only dealer sells these?
FRpilot is offline   Reply With Quote
Old 01-23-2006, 08:14 AM   #10
projectRDM
projectRDM's Avatar
No, as mentioned above any auto parts store will have them in numerous sizes.
FORMERLY R240NA
Old 01-23-2006, 09:15 AM   #11
aznpoopy
aznpoopy's Avatar
from my understanding the washers are a 'special' size so when you torque down the bolt, the opening in the banjo bolt aligns properly.
after doing it... IMO if you get any old set of washers, you could probably just overtorque the bolt a little to get it to line up properly.
Old 01-23-2006, 11:41 AM   #12
Dousan_PG
Dousan_PG's Avatar
not true
i used autozone ones and its fine. no leaks
Aaron
Pink GodziRa
