Old 02-16-2002, 11:13 PM   #1
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
WHat are the differences in the dual and single other than the obvious tips?  What r the benefits of each and the draw backs of each? are they both N/A and turbo capable or is one better for a certain application than the other?
burgy240 is offline   Reply With Quote
Old 02-18-2002, 06:38 PM   #2
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> Perhaps you should change the topic title from &quot;okay Irena&quot; haha! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
I think the difference in piping is 2.75&quot; to each pipe on a Dual vs. the 3.00&quot; piping on the single.
S13Grl is offline   Reply With Quote
Old 02-18-2002, 09:25 PM   #3
Gismo R
Gismo R is an unknown quantity at this point
I think the Dual is supposed to give a little more mid-range power than the single. Someone correct me if I'm wrong.
Gismo R is offline   Reply With Quote
Old 02-18-2002, 10:07 PM   #4
crazycuban
crazycuban is an unknown quantity at this point
Actually, the single is bigger than 3&quot;...its 80mm...(found this out after measuring the gasket to get a piece to replace my pre-muffler...it's more like 3.25-3.5 in).
crazycuban is offline   Reply With Quote
Old 02-20-2002, 05:09 AM   #5
Archangel
Archangel's Avatar
Archangel is an unknown quantity at this point
Send a message via AIM to Archangel
The N1 Dual will retain more torque and get about the same HP gains. Since its split into 2 pipes, you get more back pressure that with the N1 single, therefore you get more torque, which gives you a little better midrange, with very little top end difference from the single. &nbsp;The N1 Single would be best suited for a turbo. The dual would be a better N/A settup. &nbsp;But both would work fairly well for either.
And it looks nicer. :biggrin:
(Edited by Archangel at 7:11 am on Feb. 20, 2002)
Archangel is offline   Reply With Quote
Old 02-20-2002, 11:40 AM   #6
burgy240
burgy240's Avatar
But Irena anything with your name on it and everybody looks 8) &nbsp;.Thanks all! &nbsp;I guess the dual will still be worth it if I go SR also huh. &nbsp;I like it better anyway. &nbsp;Thanks again.
