Old 02-18-2002, 11:43 PM   #1
teampulse
teampulse's Avatar
teampulse is an unknown quantity at this point
Send a message via Yahoo to teampulse
im planning on getting apexi coilovers soon for my s14 and i am just wondering if there is any problem with coilovers clearing like 17x7 or 17x7.5 rims? and if so would i just need spacers?
(Edited by teampulse at 11:44 pm on Feb. 18, 2002)
teampulse is offline   Reply With Quote
Old 02-19-2002, 03:27 AM   #2
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
Well the stock suspension IS a coilover setup, so the aftermarket coilovers shouldn't be much if any bigger.
At least that's the way the S13 is, and I'm pretty sure the S14 is the same way.
DuffMan is offline   Reply With Quote
Old 02-19-2002, 01:15 PM   #3
Grant
Grant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura about
yea, but the spring setup is different in the front
Grant is offline   Reply With Quote
Old 02-19-2002, 05:52 PM   #4
yenpit
yenpit is an unknown quantity at this point
my understanding is there is a potential clearance prob only at the rear, only if you run a wheel wider than 9in. the reason for clearance prob is that the threaded area of the full coilover stretches further down the shock body than the stock spring perch. std lowering springs u can run any width of wheel up to 10in. this is what my supplier of my wheels told me cuz i want a wider wheel in the back vs front.
yenpit is offline   Reply With Quote
Old 02-19-2002, 06:09 PM   #5
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
My Work Wheels didnt clear my HKS Coilovers since I didnt mention I had coilovers. It was only off by like 2mm but it still pissed me off. So that is why I had bought the 5mm spacer.
You dont need to really worry with 17x7 and 7.5" wheels. Mine were 8" front and 9" rear.
If its a spring/shock combo then it wont have any problem clearing them.
West is offline   Reply With Quote
Old 02-19-2002, 06:15 PM   #6
White240sx
White240sx is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from teampulse on 11:43 pm on Feb. 18, 2002
</td></tr></table><span id='postcolor'>
It all depends on your offsets. If the wheels are a high FWD offset (+40 or greater) then you may have some issues with the inside of the wheel and tire rubbing the spring. If this is the case you will need to run spacers for the clearance.
White240sx is offline   Reply With Quote
Old 02-20-2002, 01:03 AM   #7
teampulse
teampulse's Avatar
cool. &nbsp;kind of what i thought. &nbsp;#### my 4 lug bolt pattern, hard to find those wide wheels without a 5 bolt lug pattern so i may have to settle with 7.5&quot; width.
Old 02-20-2002, 01:38 AM   #8
BadMoJo
BadMoJo's Avatar
BadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura about
Send a message via AIM to BadMoJo
or do the 5lug swap....
BadMoJo is offline   Reply With Quote
Old 02-20-2002, 02:17 AM   #9
teampulse
teampulse's Avatar
yeah i know, just felt like complaining. 5 lug conversion is already on my list of plans which should be called more like a wishlist.....
