#61 |
I am sure the Zeals are better than my KTS, but I doubt many people here are skilled enough in their driving to make up the almost $1000 difference between the $2000 zeals and $1100 kts... purely from an efficiency of spending point of view, but if someone wanted to give me one of the two... then that's a different story.
#62 | |||
![]() Join Date: Aug 2003
Petition Nissan to Make the IDx on http://IDxClub.co ! |
#63 |
![]() Join Date: Nov 2003
ooops 15 vs 16 way...
also w/ zeals i've had newbies pull amazing lap times in the zeals.. It like awd (cheating) he hehe... But back on topic i have to definitely give these suckers a test run.. And i've ridden / drove / owned quite a few coilovers in my time.
www.AutoRnD.com Nardi, Enkei, Stance, AME Master Distributors for USA Check Out Our Facebook! |
#64 |
Yeah, keep us updated. A comparison with other coilovers would be great. the shock-dyno results would be very nice too
#65 | |
![]() Join Date: Mar 2004
![]() ![]() ![]() Feedback Score: 0 reviews
ok fair enuf. i wasnt talking about drifting. but the principle still applies. i did explain how no rear sway bar would help with drifting tho. i agree a lot of people speak out of their ass, and dont understand what corner weighting is ![]() |
#66 | |
![]() Join Date: Mar 2002
PROCEED Grip Gambler |
#67 |
![]() Join Date: Oct 2003
Hello,
I will try to answer most of the questions in regarding our coilovers. Stance was developed with testing, redesigning, improving, and re-engineering. We have also learned during that time what is important in building top of the line coilover system. Internal parts have to be developed within extremely high tolerances. Also the raw material used have to be high quality in order to be able to do this. Alot of the cheaper manufacturers do not have the capability to even mimick these things. Thats why they are cheap. Stance is developed at ISO certified facility with the highest standards in the industry. All the coilovers are dyno tested for low speed and high speed force vs velocity for proper valving. What makes good coilovers and bad coilover is the dampening. Even tho there are many decent quality coilovers at low price, it takes a proper know-how to valve a coilover. This is not something that can be replicated or developed. Stance is developed with testing,research and experience. S13 and S14 models have been developed and re-engineered to our specs, here are some of the notable things. - We use 175mm springs on the front to allow extra range of adjusment(most coilovers uses 200mm-240mm). Rear shock body is short but we used extra long bottom bracket to allow very big range of adjusment. This allows you to lower your car very low or drive at stock height. - We had some problems with top pillowball mount clunking with prototype after some hard use. So we have changed original multi piece mount to a more expensive 1 piece unit. - S13 & S14 models are valved for 9k/7k springs. So we're not just throwing in the 9k/7k springs for sh*ts and giggles. Reason why it comes with 8k/6k standard is that from our experience with 8/6,9/7, 10/8 springs, we feel 8/6 is the best compromise rate for street and track. Hope this answers most of the questions you may have. Please contact us for more info. Thank you www.stancesus.com [email protected] |
#68 |
I think Dave or whoever from Touge Factory that typed up that little piece there above just has me sold on their Stance coilovers.
And I was thinking about purchasing the Silkroads prior to that... |
#70 | |
It's not so much as noticing the difference in ride quality/handling characteristics as actually needing such a good suspension set up. I guess what I'm trying to say is that most people, even some that track occasionally, aren't driving fast enough to have a set of decent coilovers like KTS hold them back, having a set of $2000 dampers is overkill, and having sticky enough tires to match coilovers is a whole 'nother story.
#72 | ||
#73 | |
#74 | |
#75 |
If you set it for oversteer it becomes too squirly and difficult to control. Also linking corners would be a pain, or early entries, holding long drifts, etc... Technically the car will understeer at entry.
I should have my review in a few days, car needs to be painted...
#76 |
I'm not saying to set it up for hardcore oversteer all the time, I'm just saying that having a stiffer rear sway bar would essentially decrease the cornering limit of the rear of the car. Doing this wouldn't cause the car to become hard to control.
Recently, I've been running no front sway bar and a HICAS rear bar and the car feels great. Early entry, holding drifts, linking turns isn't a problem at all. I don't know why you would think the car would understeer at entry. |
#78 | |
#79 |
It might understeer a little, but that's more because of driver inputs than the suspension setup. A good race car should have a little corner entry understeer, but with drifting and entering the corner way before you would if you were racing it's a little different.
With my current setup, I haven't had much, if any understeer at higher speed corners. For higher speed for me, I'm talking mid 3rd, maybe 80mph max entry to start the drift. For corners like that, it's just been a lift off or quick brake jab to break the rear loose and then counter and gas. No real understeer for stuff like that. But besides that, with a stiffer rear sway bar and a softer or no front, the car could still understeer a little, but it would be much less than with a stiffer front sway. |
#80 | |
![]() Join Date: Oct 2004
#81 |
I sold my coilovers, but I am going to try to get my friends silk roads.
wiisass - I guess its more drivers preference, I don't really like the set to oversteer thing. I love the crazy impact entry so I prefer the car to not kick out so simply. I would like to be able to grip my car with the same setup and not have to worry about it sliding on its own.
#83 |
simba, it is driver preference. I like the way I have my car set up right now with no front and the HICAS rear. It's not at the point where it will oversteer all the time, it's not even noticeable on the street. But it's set where it's just easier to initiate. And running an NA KA, it just makes things a little easier.
#84 | |
![]() Join Date: May 2004
#85 |
like what do you mean by replacement parts? What are you assuming you are going to break? Springs are laying all over the shop, there is a one year warranty I forget what they will cover, but call up TF or Stance or whatever and they will let you know what they will do.
#86 |
Well, I'm mostly worried about the struts. I've seen people break that actual strut before (buddy of mine hit a curb and snapped on of his silkroads, he's had them sitting in his garage for over a year now and hasn't been able to get replacements; it was kind of a fluke thing, but I just don't want it to happen to me). Also, knowing how long it takes to get the struts rebuilt/replaced is always a good thing.
#88 |
Ok heres my review
I picked these up from TF, comes in a nice big old box, a lot bigger than my Silk Roads. Open it up and they are all individually rapped in a whole lot of bubble wrap in thier own individual box. ![]() Every set comes with a manual, 2 wrenches, the coilovers obviously, and 5 adjusting knob caps. The caps are actually pretty nice, my Silk Roads just came with rubber caps, these can be tightened on with the allen key so they don't fall off, you can still adjust the coilovers with the caps on them. And for the slow you can read which way to go for soft or hard. ![]() The S-Chasis apps come with 9/7 springs. Front springs are shorter than the rear springs. Rear springs are the same length as Silk Roads (front and rear) ![]() First thing I did was switch out to 9/7 application. You can either take them off from the top or the bottom. I used the bottom because I have no air tools, just undo the bottom brackets and collars swap springs. The springs have no markings on them so pay attention to which you replace. After switching springs I compared them to my silk roads side by side. ![]() ![]() First thing I notice is the beffiness of these. Silk Roads are pretty beefy on their own comparing them to Tein HEs. The camber plates are thicker, the overall body is thicker. The collars on Stance are all amost the same, while on Silk Road the bottom collar for the fronts is wierdly big, the top two collars are a bit beefier too. The overall length of the coilovers are longer also, so if you want sissy height you have more than enough room. For the rears, same story, everything is beefier. The most noticeable change is the bottom mount/bracket, its almost double the length of the silk road one. The bottom mount will reach a little past the top collar, so having a long mount allows for the coilovers to go lower than the silk roads which will bottom out before the stance, also yet again allows for sissy height to the max... For both front and rear the piston is a lot bigger than the silk roads, you can tell in the picture of the rears the difference. Also Stance has shorter stroke which can be seen in the picture of the rears. My finger is on the top of the cartridge, the Silk Road sits at about another coil down. The one thing SR has and Stance doesn't is the camber adjustable bolt. On the SR it has an eccentric bolt on the top bolt for the bottom bracket. It has 4 settings. The stance bolts are offset, they sit at about setting 3 (1 away from the most camber). ![]() ![]() Those are the pics of the coilovers on. I set the ride height to a little lower than my Silk Roads. ![]() ![]() Considering its really cold (below freezing) it might take some time for these to settle. So I excpect them to a be a tad bit lower. I plan on lowering it a little more in a week or so after driving on them and painting my car. Specification wise vs. silk roads
First impression is that they are really stiff. The first time I drove them I only drove on them for like a couple minutes. They had yet to be broken in. Drove on them the next day for a little longer. They are currently at factory setting of 6 of 15. After warming up a little they fealt similar stiffness wise to my SRs at 7 of 8, just a tad stiffer. The ride isn't bouncy, but it does have that go-kart type feel to it. But it is more of a direct feel. I haven't had any track experience with them yet, considering its still snowing, but taking simple turns and weaving around in traffic feels very direct. There is not much body roll in these. Overall the valving compared to silk roads they seem to be a bit stiffer. Once the car has bumpers and lights and I have the car at its set ride height I will take it out for a little street action and mess with the dampening settings.
#89 |
wow, they look very nice! You said they are beefier, how much heavier you recon they are?
lol those blue overalls are nice too ![]() and good looking wide fenders you've got there btw. |
