Old 02-16-2006, 09:18 AM   #1
lilaznjeff
lilaznjeff's Avatar
lilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to behold
chassis electrical help!!!!!!!!!!
i have a 89 base model chassis with a sr20det in the car. one day when i decided that im going to drive this car, i realize that it dont start, i payed more attention to it, notice that im not getting power to my ecu or my dash, so i check the fuse box in the engine bay , fuse was ok, replace the relay, replace it. i realize that i will not start, i tested the fuse slot for the ecu, notice that fuse slot for the ecu is not getting power. i checked the fuse under the driver side and i also check the relay under the driver side, any other possiblity, please help thanks
lilaznjeff is offline   Reply With Quote
Old 02-16-2006, 09:53 AM   #2
the head
the head's Avatar
Location: in a dark room mastering the art of typing with one hand
the head is making a name for him/her selfthe head is making a name for him/her self
sounds like you forgot to hook all of the power leads to the battery there are three the main wire and a 2 cond plug hooked to the side
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 02-17-2006, 09:36 PM   #3
lilaznjeff
lilaznjeff's Avatar
is there another relay inside the interior, becaues when i put in the keys the radio turns on but, other than that all the interior light does not work. when i try to crank it. i chased the wire from the ecu slot i knowtice that i goes to the relay and there is a wire that attach to it which is brown, i believe it runs to motor harness.
please help
Old 02-17-2006, 10:09 PM   #4
HyperTek
does ur battery have a full charge? sounds like something minor and thankfully not mechanical... A volt gauge is a good investment for a modded car becuase you would know right away if you where getting power.
Keep it Classy
Old 02-18-2006, 04:58 PM   #5
lilaznjeff
lilaznjeff's Avatar
i have power going through the battery. i can start the car by putting the wire in to another fuse slot.
the problem is i want to start the with the key, not by popping the hood everytime.
Old 02-18-2006, 05:20 PM   #6
projectRDM
projectRDM's Avatar
I've read all three of your posts and I'm still confused. Are you trying to type in a foreign langauge?
FORMERLY R240NA
Old 02-19-2006, 02:29 AM   #7
lilaznjeff
lilaznjeff's Avatar
ok basically my car starts, it runs, the problem is im not getting power to the ecu, i check the the fuse slot its not getting power in the fuse slot on the passager side engine bay fuse box, the only way i can have power to the ecu is by putting a wire in the fuse slot in to another fuse slot. then i will be able to start the car. if i leave the wire in another slot, the power on the ecu will stay 12v constain.
Old 02-19-2006, 02:50 AM   #8
finesses240
finesses240's Avatar
finesses240 is an unknown quantity at this point
Send a message via AIM to finesses240
did you check your wiring behind the battery location? There is wires behind there that supply power to the ecu. Check those, then go from there.
*AE86 SR20 mounts*Roll Cages (any specification)**Custom Fabrication*
finesses240 is offline   Reply With Quote
Old 02-19-2006, 07:50 AM   #9
jdmsilvia909
jdmsilvia909's Avatar
jdmsilvia909 is an unknown quantity at this point
u need a wiring diagram to figure out whats going on here..see if u can find a wiring diagram cause without it u won't know where the power is travling
*Image(s) exceed(s) forum limit, strike 2*
-Moderation
R.I.P. 1990 NISSAN 240SX...U WILL NOT BE FORGOTTEN
jdmsilvia909 is offline   Reply With Quote
Old 02-19-2006, 12:33 PM   #10
lilaznjeff
lilaznjeff's Avatar
i knowtice that the slot for the ecu power goes in to the main engine bay harness, i checked driver sides relay box, and replaced it all. does theecu power goes to the driver side kick panel, does anyone have a wiring diagram,
please help thanks
Old 03-01-2006, 01:56 PM   #11
DMC
DMC's Avatar
DMC is an unknown quantity at this point
Im not sure if this is what your looking for, but i hope it helps.
EDIT: picture wont work, on he fuse box behind the drivers side kick panel, check the fuse that the second up from the bottom right corner.
DMC is offline   Reply With Quote
