Tanabe Rear Sway Bar S13
I just bought a tanabe rear sway bar and when recieved... there was no brackets or bushings for it and was wonderin if i could use another alternative to mount the sway bar onto my car... also the box said 20mm but isnt tanabe sway bar suppose to be 22mm????
ya it should be 22mm. is it sustec? i think its supposed to use the stock links and bushing. i would get some energy bushings.
Final Speed Garage- Auto repair and Performance 951-698-8161 Murrieta,CA |
Measure the make sure its actually 22mm, if it isnt, you can always return the item assuming you didnt egay it.
The stock bushings are super soft and spongy, so invest a little money into new poly bushings. I used my stock stuff with a hicas rear sway bar.. no complaints |
no, im sure that i cant use the stock bushings cause the stock sway bar is only 15mm, but the stock brackets are suppose to fit. My problem is that i dont have the bushings now.. so any ideas where i can find a 22mm bushing for the sway bar...
yeah i did buy it from ebay so i have a feeling that i wont be seeing any bushings any time soon... |
ya the box on mine said a different size for my s14 tanabe rear sway bar like it said 22mm rather then 27.5mm. Mine came with bushings..... cause its made to fit the bigger bar. but you can still use your stock links and brackets if you ahve them.
thanks guys for all the help... i emailed the guy and i think that ups lost my bughings but they are sending them now... i recieved a tracking# for a 2lbs package so i hope that it is the bushings... thanks for all your thoughts....
