Old 02-24-2006, 07:31 PM   #1
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
WTF kind of brakes do I have?
Ok...I got some brakes from a front clip (still had brake pads with the split). Rotors were waaay larger than my non-abs rotors, calipers seemed to be larger. When I got to the auto parts store, I always have to get ABS brake pads even though I dont have ABS. I had to get my rotors turned to the min. thickness and the guy recommended that I didnt put the rotors back on the car. So when I got new rotors recently I got ABS rotors, since I have to get ABS pads right? Wrong. The ABS rotors are STILL smaller than the rotors I currently have on the car. Put them on the car with the caliper and they were just too small to account for the caliper. The rotors are already 4-lug, not drilled so obviously these are OEM on some 240sx (180sx/silvia?)
Are they altima rotors here in the US?:
Also, it looks as if the amount of contact that the pad is touching is about the same size as the new ABS rotor. Should the pad contact be closer to the center of the old rotor? (see the ring of "rust" closer to the center of the rotor):
Damn Im confused
Neejay is offline   Reply With Quote
Old 02-24-2006, 07:44 PM   #2
g6civcx
g6civcx's Avatar
I'm confused as well. What are you asking?
That looks like JDM 180SX brake discs. Try getting 93-97 Altima discs and 95-99 Maxima pads. Those should fit your JDM calipers.
Old 02-24-2006, 07:46 PM   #3
Neejay
Neejay's Avatar
That looks like JDM 180SX brake discs. Try getting 93-97 Altima discs and pads. Those should fit your JDM calipers.
lol I was asking what kind of rotors do I need and what kind of brakes do I currently have.
So I need altima discs and maxima pads? hmm...
Old 02-24-2006, 07:52 PM   #4
Steve_S14
Steve_S14 is an unknown quantity at this point
the 180sx in japan comes with bigger brakes than we have here.
its the same as 1995 maxima calipers and 1995 altima rotors (4x114.3).
get altima rotors and you should be good, thats the upgrade i did on my s14 and its a big improvement over stock
Steve_S14 is offline   Reply With Quote
Old 02-24-2006, 07:52 PM   #5
g6civcx
g6civcx's Avatar
Originally Posted by Neejay
lol Im asking, what kind of rotors do I need?
Do you know what front clip it was? If it was a 180SX then yes, get what I posted above.
Old 02-24-2006, 08:00 PM   #6
Neejay
Neejay's Avatar
Should I get ABS for the rotors and pads?
Old 02-24-2006, 08:08 PM   #7
g6civcx
g6civcx's Avatar
You don't have a choice. They're all the same. 240SX abs vs. non-abs are different, but for the Altima and Maxima for that generation it's all the same.
Old 02-25-2006, 10:26 AM   #8
Neejay
Neejay's Avatar
Thanks man. Now my other question is this: Shouldn't the pad make more contact (closer to the center of the rotor) than its making?
Old 02-25-2006, 01:18 PM   #9
g6civcx
g6civcx's Avatar
That looks about right. Take out your brake pads and measure them against the discs and see. If you're running the right pads there should be no overhang or shortage.
Old 02-25-2006, 06:59 PM   #10
Neejay
Neejay's Avatar
Thanks. I got the altima rotors and although I havent side-by-side compared, they look bigger and seem like they will work. An interesting side note is that the Maxima pads and ABS 240sx pads had the same part number.
