Old 02-26-2006, 08:36 PM   #1
Ricks15
Ricks15's Avatar
Ricks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud of
How to remove the tar from inside the body
Ive been riding my car with a stripped out hatch but the tar thats inside the car is a bitch to take off I used a hammer and a chisel and some of it comes off but I leave a bunch of crap on the metal that still is stuck on there, Do you think acetone would remove it with ease???? Or maybe someones tried something else to remove it???
Ricks15 is offline   Reply With Quote
Old 02-26-2006, 08:36 PM   #2
Ricks15
Ricks15's Avatar
Old 02-26-2006, 08:41 PM   #3
bluuuurr
bluuuurr's Avatar
bluuuurr is an unknown quantity at this point
on one of my hondas, i used dry ice... if you break up the dry ice and scatter it across the tar, the tar constricts making it alot easier to break off plus it comes off in big sections. It won't leave little boogers all over the metal and you won't have as many scratches.
as for the leftovers, just give them a good scrubbing with a heavy degreaser..
bluuuurr is offline   Reply With Quote
Old 02-26-2006, 08:43 PM   #4
projectRDM
projectRDM's Avatar
No one has ever tried doing this, ever. Not even in the 45+ years car manafacturers have been applying the material.
Obviously, because you couldn't find your answer anywhere else.
Old 02-26-2006, 08:59 PM   #5
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
dry ice does wonders
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 02-26-2006, 09:15 PM   #6
kandyflip445
kandyflip445's Avatar
You can use dry ice. I forgot the other way to do it. There are plenty of other ways, and there are plenty of people here that have done it.
My 240 vBgarage
Old 02-26-2006, 09:56 PM   #7
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
i think u can use gasoline
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 02-26-2006, 10:01 PM   #8
ae86driftn
ae86driftn is making a name for him/her selfae86driftn is making a name for him/her self
Dry ice is the easiest to remove the sound deading. Tar?
ae86driftn is offline   Reply With Quote
Old 02-26-2006, 10:08 PM   #9
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
DOnt use gas, since you are likely to die.
Here is the only worth while ways of sound deadening removal.
Dry ice. Spread it over the sound deadening, and let it sit at least 25 mins. Then hit it with a hammer and chisle.
Air Chisle.
Hammer, and chisle.
Once thats gone, use a large while wheel and remove all the residue, and then take asitone, and whipe it clean.
blu808 is offline   Reply With Quote
Old 02-26-2006, 10:08 PM   #10
Shawn_of_the_Dead
Shawn_of_the_Dead's Avatar
Shawn_of_the_Dead is on a distinguished road
wow...I didn't know dry ice worked. I was gonna suggest a heat gun and chisel or drywall scraper.
'93 Coupe BlkTp-SR
'07 Chevy HHR - DD
Shawn_of_the_Dead is offline   Reply With Quote
Old 02-26-2006, 10:11 PM   #11
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
i use a heat gun and a scraper... only works well on newer cars tho.... wire wheels are definetly good at stripping that crap off...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 02-26-2006, 10:27 PM   #12
ALTRNTV
Dry ice is by far the easiest. All you do is lay it on there, for about half an hour, as Luke said, and just chisel it out.
ALTRNTV is offline   Reply With Quote
Old 02-26-2006, 10:48 PM   #13
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
i just used a hammer/chizle/flathead, left a lot of stuff, took a lot of time taking it off cleanly without denting/scraping the surface area too much, but it was worth it (got flooring painted) just try to chizle/scrape off as much as you can then use acetone to wipe/clean it off, i wouldn't suggest a wirebrush just because it leaves swirlmarks, looks uglier and it leaves more prepwork n such for paint.
Indolent is offline   Reply With Quote
Old 02-27-2006, 12:11 AM   #14
Ricks15
Ricks15's Avatar
Where do you guys think I can get some Dry Ice at????
Old 02-27-2006, 12:14 AM   #15
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
safeway or liquer stores will carry it. It works like a charm.
DJPimpFlex is offline   Reply With Quote
Old 02-27-2006, 12:16 AM   #16
ALTRNTV
Nice interior Mark. I wouldn't anchor your Takatas' there though. Get a harness bar.
Old 02-27-2006, 12:57 AM   #17
2iv0 sx
2iv0 sx's Avatar
2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute
I would always stop the ice cream truck and ask the lady.. she always gave me a block, worth a try.. haha
2iv0 sx is offline   Reply With Quote
Old 02-27-2006, 09:32 PM   #18
scarecrow
scarecrow's Avatar
scarecrow has a little shameless behavior in the past
what about peanut butter?
scarecrow is offline   Reply With Quote
Old 02-27-2006, 09:52 PM   #19
ae86driftn
yeah,that stuff is awesome,goes well with jelly
Old 02-27-2006, 10:40 PM   #20
ramblux
ramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of light
Dry ice/hammer. Anything else is a waste of time.
Seriously.
ramblux is offline   Reply With Quote
Old 02-28-2006, 01:49 AM   #21
Flybert
You stripped yours to win points at the show? Looks like it seeing how you have your harnesses mounted.
Wire wheel is perfectly fine. After throwing wheels, tool boxes, and jacks in the back, paint gets effed up anyways.
Old 02-28-2006, 03:00 AM   #22
blu808
blu808's Avatar
Well the inside of my fd looks like that and i didnt do it for show points.
What makes you think he took time, care, and labor, just to win a show?
I think he did it because he doesnt want his car looking like crap.
Old 02-28-2006, 08:41 AM   #23
g6civcx
g6civcx's Avatar
That's a nice looking car.
Old 03-03-2006, 01:30 AM   #24
sdtouge
sdtouge can only hope to improve
what i have always done is just hammer and chisel it out when its dry just as is no dry ice, then get this solvent called desolveit. its really good, just spray it on let it sit for like 30 min or an hour, then come back with like a scrubber hand brush thing and srub it off. this may take a couple coats, but after it looks really clean and you dont have to paint it either. did it on my s13 and on my 14, for s14 i hghily recomend you remove the dash cause you can get alot more of this random rubber insalator crap nissan gave you.
sdtouge is offline   Reply With Quote
Old 03-03-2006, 10:34 AM   #25
HyperTek
that car also has a r32 full body conversion and rhd.. definitly show..
Regular super market ice works too.. just messy and i wasnt thinkin about dry ice
Keep it Classy
Old 03-03-2006, 10:59 AM   #26
FRpilot
FRpilot's Avatar
yea regular super market ice works and is way cheaper. unless you have a drain hole, it is messier because when it melts, you get a little pond in your car with everything thats washed in floating in the pond (broken up sound deadening, fur from the carpet, coins and pieces of french fries that you dropped in your car and forgot about, etc)
the reason for using dry ice is because when it melts it evaporates into the air. $20 for like a few lbs of dry ice vs $2-3bag of ice is a bit of a difference, but i think its justified for all the headaches of the pond it creatse.
FRpilot is offline   Reply With Quote
Old 03-03-2006, 11:25 AM   #27
xka24detx
xka24detx is an unknown quantity at this point
ATF.. yeah auto tranny fluid.. im not kidding.. when i had my 5 spd swap done i had my AT tranny in the back on the drive home and spilled alot of fluid back there and it soaked in or something and the sound deadening came off like butter in almost one big piece with a flat head screw driver and a rubber mallot.
xka24detx is offline   Reply With Quote
Old 03-03-2006, 12:43 PM   #28
sdtouge
as long as the end justifies the means.
Old 08-30-2006, 03:32 AM   #29
Bay_Area_sr20det
Bay_Area_sr20det is a well-known jackass
Send a message via AIM to Bay_Area_sr20det
hmm, i went to safe way and got dry ice about 2 hours ago, in the morning i will buy atf and see how that works also. thx for all the info guys.
ohh i already weighed the hard tar under the dash pluss the wered ass seccond ac condencer between the blower motor and heater core, 45 lbs just under the dash.
Speed Kills, Drive A Honda Live Forever!
Bay_Area_sr20det is offline   Reply With Quote
Old 08-30-2006, 03:58 AM   #30
projectRDM
projectRDM's Avatar
You dredged up a five month old thread for that?
