Old 02-19-2006, 10:59 PM   #1
IAM_SO_sLOw
IAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choices
Send a message via AIM to IAM_SO_sLOw
SR lawn mower/whOOo!!! sounds
alright my car is deciding to give me problems one right after another....
alright i recently replaced my turbo because it had too much shaft play and then i noticed a clicking sound...kinda sounding like lawn mower a clicking sound.... but the sound only come when i throttle...during idle there is no sound or when i left off the gas.... i cant seem to pin point where its coming from either?
second problem today.... i started up my car and started to hear a WHOooooo sound when i would throttle also....it comes and goes useally from 2000-4000 rpm.... i poped my hood to see what would be causing it which leads me to another problem... i saw some like fresh resudue around the water pump assembly...would this cause the WHOooo sound? lol
lol does anyone know what im talking about =)
-thanks any help would be appreciated btw: i got a s13 blacktop
IAM_SO_sLOw is offline   Reply With Quote
Old 02-19-2006, 11:11 PM   #2
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
that whoooo sound could maybe the water pump going. Is there alot of coolant around the pump? To bad you having problems, didn't you just get this engine?
drifter808 is offline   Reply With Quote
Old 02-19-2006, 11:14 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
Why can't you pin point the noise? Can you give a general direction? Depending on where the ever-so descriptive "whooo" noise is coming from, it could be a few different things.
Try harder and come back.
Old 02-19-2006, 11:15 PM   #4
IAM_SO_sLOw
yeah =*( i did....theres not alot of coolant around the pump like a noticable ring...
all these problems kinda started to pop out when one of my friends told me to run a open waste gate to get to 14psi =( stupidest thing i have ever done...
Old 02-19-2006, 11:33 PM   #5
IAM_SO_sLOw
well the lawn mower/ clicking sound sounds like its coming from within the block...
the whoo sound sounds like the front of the motor...sounds like its coming from the water pump
Old 02-21-2006, 12:44 AM   #6
IAM_SO_sLOw
ok i listened more carefully....sounds like the lawn mower sound is coming from the back of the motor....around the exhaust manifold...
Old 02-21-2006, 01:21 AM   #7
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Open wastegate + a ton of problems?
DO a compression test.
Congratulations.
You may just have blown your motor.
#4 cylinder is almost ALWAYS the first to go and that sound you describe makes me think of knock.
OR if you're super lucky...
The lawnmower sound is just a bad exhaust leak, and you blew out a turbo gasket.
Maeda is offline   Reply With Quote
Old 02-21-2006, 02:50 AM   #8
TougeSR20Kid
TougeSR20Kid's Avatar
TougeSR20Kid has a little shameless behavior in the past
SR
Removed by author
TougeSR20Kid is offline   Reply With Quote
Old 02-27-2006, 12:05 AM   #9
bktman
bktman is an unknown quantity at this point
SR
I'm having the exact same problem but I'm running a AEM tubular manifold, Just upgraded t28 s15 turbo and upgraded up pipe. I also started to hear this noise when I was boosting 14lbs by accident when it crept up.
the noise does sound like a lawnmower under load between 1000 - 2500 rpm and worse under load. The noise doesn't sound as bad when the car has been running for a while. Kinda sounds like a leak but I won't rule out the fact that I've damaged my motor.
thanks
Tommy
bktman is offline   Reply With Quote
Old 02-27-2006, 12:14 AM   #10
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
do you have e-fans, or the clutch fan? clutch fans make whooooo sounds with the engine is revved. and if you have that residue, your water pump may be going too.
lawnmower sounds usually do mean exhaust leaks. I have many, and it ain't pretty. it might just be a gasket
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 02-27-2006, 12:19 AM   #11
IAM_SO_sLOw
nah i didnt blow my motor...the compression was still good... umm...the whooo sound... was solved by getting a new water pump....and i did mess up my cheap t25 turbo...but got another one.... the lawn mower sound comes and goes... i have a strong feeling its a exhaust leak somewhere...
Old 02-27-2006, 01:11 AM   #12
CHARLIE2020
CHARLIE2020 is an unknown quantity at this point
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
You can have perfect compression but still have spun rod bearings, that usually has a knocking type sounds and should increase with RPM.
CHARLIE2020 is offline   Reply With Quote
