How to install Driver's side Window?
I am installing the driver's side window onto my S13. It should be easy, but I'm having a hard time getting it correct. I have it properly lined up when I do the install. The window closes perfectly. But when I lower the window all the way down (power window) and raise it back up, it doesn't line up at all. There is a gap and the window gets offset. I've tried several times without success. Does anyone know the PROPER way to do the window install?
![]() Join Date: Dec 2002
The FSM clearly describes the adjustment procedures. If you haven't done anything besides pulling the glass you shouldn't have an alignment issue, if you have then it takes a lot of fine tuning to get the stops and rails just right.
Yes, I did replace the glass window. I also looked at the fsm before I did the install and saw the points that need to be lined. I'm going to try another trick that I read on another forum to see if it works once it stops raining. Thanks for the reply.
