Old 03-07-2006, 03:09 PM   #1
spoonfed
spoonfed is an unknown quantity at this point
KA24E - Idle normal for 1 second then creeps up to 2krpm?
Hi,
I've read a few posts, maybe the IACV, TPS or vacuum leak. I've checked my tubes and they seem ok and unplugged the TPS which lets it creep up to 2200rpm. I'm not exactly sure how to check the TPS. But this problem happened in between my leaky injector problem. So i'm not sure if its related. All injectors are replaced now and no signs of leak so far. The car drives normal but when you come to a stop, it will idle normal for a second and slowly crawl up to 2k.
Could maybe a bad injector do this? I bought four "tested" used ones from ebay =/
Thanks ahead of time!
spoonfed is offline   Reply With Quote
