Old 03-09-2006, 12:18 AM   #1
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
How to seal shroud against radiator?
I am going to be using a Taurus fan on my Koyo, and the fan/shroud fits damn near perfect, except on the ends there is about a 3/4" gap between the shroud and the radiator core. What can I use to seal this gap up? I was looking in the autoparts store and all they seemed to have was some dinky weatherstripping.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 03-09-2006, 12:20 AM   #2
S14DB
AFC #1
S14DB's Avatar
Window Weld works wonders. What's wrong with the weatherstrip?
Garage door weatherstripping is nice.
Old 03-09-2006, 12:22 AM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
Weather stripping would work actually. RTV it on.. or JB WELD! hahah
Old 03-09-2006, 12:32 AM   #4
andrewmp6
andrewmp6 can only hope to improve
jb weld and duct tape fixes anything
andrewmp6 is offline   Reply With Quote
Old 03-09-2006, 12:32 AM   #5
sunnys14
sunnys14's Avatar
sunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nice
thats what i was gonna say... JB WELD!
sunnys14 is offline   Reply With Quote
Old 03-09-2006, 09:18 AM   #6
boosteds13
boosteds13's Avatar
Ok, but we're putting it on yours first.
Old 03-09-2006, 09:20 AM   #7
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
jb weld, rtv and duct tape to fill gap between fan shroud and radiator? Oh man that is really ghetto and will look like ass... I second the weather stripping or foam tape of some kind, it'll probably seal better and look much better.
How are you attaching the fan/shroud to the radiator? With my altima dual fan I just ended up using zip ties on the top and bottom corners, but there is probably a better way. If you don't already know this, how close the blades are to the core plays a huge role in how well they pull air through the raidator (sealing around the shroud will really help too). At one point I had some overheating problems that were caused by me not using zip ties on the bottom of the fans, which caused them to pull away from the core about 1" and pretty much killed the cooling effect of the fans == overheat. The taurus fan has a much nicer shroud so it's probably won't be as big of a problem for you... You should post some pictures when you have them happily installed
MELLO*SOS is offline   Reply With Quote
Old 03-09-2006, 09:40 AM   #8
NemeGuero
No more nissan.
NemeGuero's Avatar
It'll only look ghetto if you don't put enough time in it. If you do it right, it'll look good.
Just spend some good time on it. Do it cleanly and paint it. Haha
