Old 03-16-2006, 11:02 AM   #1
drrifto
drrifto is an unknown quantity at this point
clutch slave problem after SR swap
Im posting for a friend of mine that got an SR swapped into his 89. All is okay except for the clutch that was slipping (stock SR clutch) in all gears, not as noticeble in 1st gear.
Clutch was bled multiple times and the master and slave cylinders were replace. I tried adjusting the clutch and gave it plenty of throw so I could make sure that it was completely engaged and the problem was still there. I took a look at the fork and saw that there was a still pressure on it and the slave was fully depressed. I unbolted the slave and went for a ride starting in 2nd and the slipping was gone. As of right now, the rod is grinded down so it works how it is suppose to.
Now my question is, is there different slave cylinders? The one being used was for an 89-95 240sx from Autozone. If the slaves are all the same then maybe something is off with the fork, pressureplate or the throwout. Doesnt seem like its slipping but I wanted to make sure that he doesnt sh!t a clutch if it is still not completely engaging....I didnt want to grind too much off the rod. Any info is greatly appreciated. Thanks.
drrifto is offline   Reply With Quote
Old 03-16-2006, 11:30 AM   #2
curbhuggerrps13
curbhuggerrps13's Avatar
curbhuggerrps13 is an unknown quantity at this point
Send a message via AIM to curbhuggerrps13
try routing the clutch line drectly to the slave and bypass the clutch box...fixed my problem in a jippy
curbhuggerrps13 is offline   Reply With Quote
Old 03-16-2006, 01:45 PM   #3
Dousan_PG
Dousan_PG's Avatar
you have to bleed the dampner box as well as the slave to get the air out
the easy way is to remove the dampner box and just bleed the slave
i kept my dampner and put a speed bleeder on the slave, i only bleed off the slave now and its perfect.
Aaron
Pink GodziRa
Old 03-16-2006, 02:25 PM   #4
drrifto
Sorry I didnt include this in the first post, the dampner box was removed. It doesnt seem to be a fluid problem because the slave cylinder piston is in the farthest it can go and its tight on the fork when bolted down. Its pushing it enough that the clutch is not completely engaged.
