Old 03-24-2006, 02:04 PM   #1
d-oom
d-oom is a well-known jackass
HELP! Daily Driver Down!!
well, i have to be at work right now.... all i did was take out my old dash and gauge cluster, and put in a new ones.
im fixing to do a sohc to dohc swap, and i figured that i should go ahead and swap out the gauge clusters while im at it. bad idea i guess.
the new cluster randomly reads the tach, and it does speed fine.
i know its not going to read it right
please help so i can get to school and work!
d-oom is offline   Reply With Quote
Old 03-24-2006, 02:15 PM   #2
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Is it just me or is anyone else confused?
Jung918 is offline   Reply With Quote
Old 03-24-2006, 02:45 PM   #3
FRpilot
FRpilot's Avatar
it is a known fact that sohc guage cluster doesnt work with dohc swap. the tach signals are different. speed sensor works. thats why ppl who do dohc ka/sr swaps use the dohc guage cluster or swap tachs.
to fix this, swap back your sohc gauge cluster or just the tach.
FRpilot is offline   Reply With Quote
Old 03-24-2006, 02:46 PM   #4
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
What do you need your tach for to get to work? Just drive it and fix it tomorrow.
SpeedMonkeyInc is offline   Reply With Quote
Old 03-25-2006, 12:25 AM   #5
d-oom
sorry, i had to write this in like 30 seconds before i bumed a ride to work.
i was replacing a dash in my 1990 sohc 240sx. i have plans, and the engine, to do a dohc swap. i put the new dohc cluster in knowing that it wouldnt read right. i went ahead and did this because the dash was off and stuff.
i went to drive it, and its studdering, skipping like its off timing or something. no power. it doesnt make sence that swapping a different gauge cluster would do this? thats litterally all i did.
Old 03-25-2006, 01:28 AM   #6
VitaminT
GhettoBoost
VitaminT is making a name for him/her selfVitaminT is making a name for him/her selfVitaminT is making a name for him/her self
Swapping clusters won't have any difference on the way the motor runs. Now something you left unplugged while the dash was off might. The only thing I am not sure on is if you have to use a dohc cluster harness with the dohc cluster and sohc with sohc. I am pretty sure it will work with either harness though.
VitaminT is offline   Reply With Quote
Old 03-25-2006, 01:33 AM   #7
m072514
m072514's Avatar
m072514 is an unknown quantity at this point
Send a message via AIM to m072514
DE cluster will show speed on the SOHC, and vice versa... but the rpm's wont read right unless your engine matches the cluster... someone correct me if im wrong.
m072514 is offline   Reply With Quote
Old 03-25-2006, 07:53 AM   #8
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
You're right, I just did the swap last weekend, You need the SOHC cluster and the DOHC tach, to work with the ''DE'' swap. The SOHC tach doesnt work at all after the swap.
As for your problem, I would first, check fuses, installing the dash and gauge pod could have poped a fuse, than I would pull the dash and go back through what you did, They're right that you might not have hooked somthing up, or you could have inadvertantly pinched somthing in the install. I used the SOHC harness under the dash, and built a jumper to connect to the ECU, sorry this so long, GOOD LUCK.
NIK90s13 is offline   Reply With Quote
Old 03-25-2006, 09:25 AM   #9
g6civcx
g6civcx's Avatar
Not to pick on you, but the entire cluster minus tach will work on any S13. The tach follows the engine. SOHC and DOHC are NOT interchangeable.
Sounded like you said that you need SOHC cluster to swap to DOHC. You can use a DOHC cluster as well, which is actually the best way to do it since it will have the DOHC tach for you.
Good avice all around though.
Old 03-25-2006, 12:04 PM   #10
d-oom
i guess i might have left something unplugged, i was in a hurry. ill go back and check
Old 03-25-2006, 12:12 PM   #11
NIK90s13
NIK90s13's Avatar
I used my SOHC pod, and only changed the DOHC tach. I know you can use both, I wanted to use the SOHC pod.
Old 03-25-2006, 01:33 PM   #12
d-oom
well, thats wierd....
somehow one of my sparkplug wires got disconnected.... sounds like sabotage to me
my tach doesnt do shit lol, at least the speed reads right.
Old 03-25-2006, 03:42 PM   #13
NIK90s13
NIK90s13's Avatar
That's cool you found it, At least you did'nt have to pull the dash again, I put in a dash last summer, not bad, but I do'nt want to do it twice in a row.
