Old 03-21-2006, 08:14 AM   #1
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
z32 problems (once again) sr20det
so i had my car running for a week perfect. It is soo fast, before the car idled perfect 900rpm ish. Now the car shakes violently at idle and is very slow. All of a sudden when driving i heard a loud backfire and the power instantly cut off. Can maf's go bad like this? i'm using a z32 maf and safc2 setting are 2in 5 out i'm using a s14 sr20det.
When i unplug the maf the car idles like once before.
when i plug the maf in, car wants to die.
Checked wiring it seems good.
sblack13 is offline   Reply With Quote
Old 03-25-2006, 01:34 PM   #2
curtflirt
curtflirt is an unknown quantity at this point
Send a message via Yahoo to curtflirt
help
I have an sr20det s14 blacktop with an s14 mafs. If i upgrade to a z32 mafs and 550 nismo injectors, would I have to flash my ecu if I have a safc.? And how do I set it if I don't need a flash.
I also have a similiar problem with my stock mafs. This is why i might need to upgrade sice there are no s14 mafs available.
curtflirt is offline   Reply With Quote
Old 03-26-2006, 03:41 PM   #3
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
are you sure that you didn't blow an intercooler pipe loose?
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 03-26-2006, 05:30 PM   #4
smithers584
smithers584 is an unknown quantity at this point
curtflirt, dont ever come into a thread that someone has started so they can receive help and then ask a totally different question. its ok if you have the same problem, but tuning and ecu's should be another thread. if you want answers to that, start another thread you will receive them.
as far as your mafs go, have you shot it with a meter to check for your voltage? i believe its .8v-1.5v at idle and 1.4v-2.0v at 3000rpm between pin 1 and ground. make sure the engine is warmed up. i also agree with checking your intercooler piping. if you have a SAFC, it has a sensor check, IN 1 is your maf, you can use that to read the voltage from.
smithers584 is offline   Reply With Quote
Old 03-31-2006, 11:09 PM   #5
sblack13
sblack13's Avatar
lol i feel like a dumbass, this was the problem. gahh.
Old 04-01-2006, 12:24 AM   #6
andrewmp6
andrewmp6 can only hope to improve
sblack your maf is bad or hooked up wrong or you got a intercooler pipe loose
andrewmp6 is offline   Reply With Quote
Old 04-01-2006, 06:31 AM   #7
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
Wow!!! You should read my Z32 MAFS write up...your settings are fucked up and I hope you didnt jack up your motor 4 life...
Hint Hint
In and out settings are wrong bro...
http://www.zilvia.net/f/showthread.php?t=97556
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline   Reply With Quote
Old 04-02-2006, 07:54 PM   #8
kuramaya
I didnt see any reply, what happened?
Old 07-31-2009, 12:26 PM   #9
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
Hint Hint
sorry to bring up an old thread but i was searching this topic and figure id help other ppl searching this
i read your how to. i love it.
but the 2in and 6 out doesnt work for an s14sr and a s15sr ( or so ive read)
the correct settings for a s14/s15 are 2in and 5out
Black240Ct is offline   Reply With Quote
