Old 03-30-2006, 06:26 PM   #1
kenversusryu
kenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nicekenversusryu is just really nice
bad gas mileage before and after tune-up
so ever since i installed a ram-air setup on my 95 240sx i went from 27mpg city/highway to 21.
I removed it and changed my spark plugs, fuel filter, o2 sensor, coolant change/flush, oil change, injector cleaner and I'm still getting bad gas mileage.
I guess i'll replace the distributor cap, rotor and maybe the coolant temperature sensor but what else could be causing this really bad gas mileage? should i check timing? The car runs good and no noticable problems at all. I ran a self diagnostic as well and came up 55 (no problems)
I am desperate for help. What else do i have to replace or check??
kenversusryu is offline   Reply With Quote
Old 03-30-2006, 07:16 PM   #2
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
Could be anything. I would check the TPS and make shure that it hasn't moved from it's stock settings. If timing is advanced or retarded to far it could also decrease gas mileage since the cams aren't properlly alighned.
BigVinnie is offline   Reply With Quote
Old 03-30-2006, 10:41 PM   #3
Blues13
Blues13 is an unknown quantity at this point
check your tire pressure and also your fuel lines. There is also a rubber hose for the fuel line by the gas tank in the back.. make sure it didnt develope a small leak.
Blues13 is offline   Reply With Quote
Old 03-31-2006, 01:38 AM   #4
kenversusryu
tire pressure is checked regularly and i doubt theres a leak in the fuel line. otherwise i would've smelled gas eminating from my garage everytime i worked on my car.
how does a throttle position sensor move from its setting? What's the normal setting?
Thanks for the suggestions....
Old 03-31-2006, 05:12 AM   #5
Nizmo240_22
Nizmo240_22 is an unknown quantity at this point
True this could be the case, but ignition timing is independent to cam timing.
Nizmo240_22 is offline   Reply With Quote
Old 03-31-2006, 05:13 AM   #6
Nizmo240_22
.45-.55 volts at closed throttle IIRC.
Old 03-31-2006, 05:39 AM   #7
mrmephistopheles
mrmephistopheles's Avatar
I've found that the biggest enemy of fuel economy is a spirited right foot.
Double check everything. If that fails, try your stock intake again.
Originally Posted by PHLIP
Old 03-31-2006, 10:17 AM   #8
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
werd
got pictures of this ram air setup, maybe it is messing up the MAFs signal.
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 03-31-2006, 05:35 PM   #9
kenversusryu
i removed the ram air setup. if the maf signal is bad.. wouldn't it affect drivability? at idle ?
Old 03-31-2006, 06:10 PM   #10
krustindumm
might only effect it when your moving, only way to tell is a DSO and maybe a wideband, or a Consult or similar graphing scan tool.
Old 04-03-2006, 09:55 PM   #11
kenversusryu
okay here's an update.
Checked timing.. it was perfect at 20degrees
then i checked voltage on maf. Here are the results.
.5 volts at ignition on which is normal.
1.27 volts at idle which is low but still normal
2.5 volts at 4k rpm which is NOT normal... should be 4 volts.
could a weak maf signal at 4k be the cause of all the bad mileage? That would make sense since the ram air could indeed have messed up the maf somehow. The car itself runs just fine.. no bogging.. no rough idle or anything.. but the 2.5 volts at 4k is the weird part. Any suggestions or advice?
Old 04-03-2006, 11:12 PM   #12
krustindumm
Isn't it a 5V reference signal? In that case 4V at 4krpm unloaded would be way too high. I think you should be seeing 2.1-2.2 at 2500rpm.
I always use the consult-II and watch g/sec though.
Old 04-04-2006, 03:53 AM   #13
kenversusryu
it says on the fsm that it should be 4volts at 4k rpm. I don't have a consult.
