View Poll Results: Ceramic coating
Coat both the inside AND outside. 7 63.64%
Coat only the inside (why?) 0 0%
I am a fool with no experience in this subject. 4 36.36%
Voters: 11. You may not vote on this poll
Old 04-03-2006, 05:28 PM   #1
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Question ceramic coating turbo manifold.. Inside and outside?
I want to have my HKS cast bottom-mount manifold for my RB ceramic coated. What are your opinions on having both the inside and outside coated vs just doing the outside?
Some people have said that doing the inside isn't suggested or common because the ceramic could "flake" or otherwise come off and go into the turbine. I've never heard of this, but a few different people have mentioned it.
Others I speak with say that it's common to do both the inside and the outside. I think this would offer twice the thermal barrier as just doing the outside. This would result in the exhaust gas retaining more energy and the engine bay being cooler. I also plan on having the turbine housing coated, but again I'm unsure if I should just have the outside done or inside + outside.
Please share your thoughts, opinions and experiences with ceramic coating (cast) turbo manifolds and/or turbine housings.
MELLO*SOS is offline   Reply With Quote
Old 04-03-2006, 05:43 PM   #2
nismojason
nismojason is an unknown quantity at this point
can't help but would also like to hear what people have to say about this.
Jason
nismojason is offline   Reply With Quote
Old 04-03-2006, 06:25 PM   #3
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
damint i cant believe i dont remember what i did, i think that i only had the outside done but maybe i did get the inside coated as well, at any rate there was a discussion about the physics of having the inside coated, where it will allow the hotter gasses to pass through the exhaust which means quicker turbo spool or something. Im sure someone has more info on this.
mjjstang is offline   Reply With Quote
Old 04-03-2006, 06:32 PM   #4
originalsin
originalsin has a little shameless behavior in the past
id say do inside and out, i mean say the stuff does flake off, i rly dont see it hurting the turbo, its not like its metal, its going to be chips like paint coming off, which will prolly get busted apart by the turbine and blown out the exhuast...
originalsin is offline   Reply With Quote
Old 04-03-2006, 06:39 PM   #5
g6civcx
g6civcx's Avatar
Give http://www.swaintech.com/ a shot.
Old 04-03-2006, 08:56 PM   #6
PoorMans180SX
PoorMans180SX's Avatar
swaintech is sweet. As long as you have a reputable company coating your manifold, it shouldn't flake off. Inside and out for sure, hotter exhaust=faster turbo spool. I plan on having my exhaust ports ceramic coated as well. When I get the money that is ....
Old 04-04-2006, 03:33 AM   #7
koukidough
koukidough's Avatar
koukidough is an unknown quantity at this point
i wouldnt do it, just the outer part is fine.
1997 Nissan S14 SE Redtop SR20DET @12psi
1999 Honda Civic Hatch EK9 N/A b16a2 (SOLD)
koukidough is offline   Reply With Quote
Old 04-04-2006, 04:38 AM   #8
S14DB
AFC #1
S14DB's Avatar
Urban legend. People think of the old painted headers that flake off. Ceramic coating is like Powder Coating. It does not flake off.
The inside should be coated to keep heat from transferring into the metal and slowing the exhaust charge. The outer coating is for appearance, environmental protection and further heat protection.
Old 04-04-2006, 08:02 AM   #9
sxse240
sxse240 is on a distinguished road
Some of the coating shops won't give you an option and will only coat both surfaces.
sxse240 is offline   Reply With Quote
Old 04-04-2006, 09:04 AM   #10
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Thank you guys for the response! Looks like I'll be doing both inside and out of the exh manifold and the turbine housing.
Somehow Swain Tech slipped past me before, thanks for the link. Here's one in return: www.performancecoatings.com - suggested to me by the (N/A baja truck) race team across the street here.
Old 04-04-2006, 09:09 AM   #11
S14DB
AFC #1
S14DB's Avatar
If it is used. Make sure to hot tank it before coating.
