Old 04-09-2006, 02:20 AM   #1
yusuke1923
yusuke1923's Avatar
yusuke1923 is close to perfectionyusuke1923 is close to perfectionyusuke1923 is close to perfectionyusuke1923 is close to perfectionyusuke1923 is close to perfectionyusuke1923 is close to perfectionyusuke1923 is close to perfectionyusuke1923 is close to perfectionyusuke1923 is close to perfectionyusuke1923 is close to perfectionyusuke1923 is close to perfection
Exclamation Koni Yellows Weak?? Help!!
Hello all, I just installed the "KONI YELLOWS" Struts on my 180SX.
Aren't the these suppose to be REALLY REALLY STIFF?
Somehow they are not... I set them to the maximum STIFF-NESS...
When I drive... the drive is not hard.
So my question is... are the "KONI YELLOWS" really STIFF?
What is it equivalent to?
Help!!
yusuke1923 is offline   Reply With Quote
Old 04-09-2006, 03:29 AM   #2
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
hopefully you got the right ones
anyway, they theoretically have an infinite adjustability range.
what springs do you have them on? they are just dampers, man. THE BEST, but still dampers.
Did you install the inserts correctly?
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 04-09-2006, 09:20 AM   #3
SoSideways
SoSideways's Avatar
Perhaps you're just experiencing the uber goodness that is the Koni shocks?
I remember reading when guys were complaining about how they don't feel the pot holes or bumps with their Apexi N1 Pro 2001 model, and they thought the whole set was busted, until someone chimed in and said that it's just cause it's damping is so f-ing awesome, that it soaks up bumps and pot holes like jello, and that while cornering at the track, the car still stays flat.
Old 04-09-2006, 11:09 AM   #4
yusuke1923
yusuke1923's Avatar
The insterts are intalled properly...
The car does stay flat on corners though.... I mean it doesn't even budge...
Old 04-09-2006, 02:55 PM   #5
EchoOfSilence
then are you complaining about? hahahaha.
I want uber-goodness
Old 04-09-2006, 04:02 PM   #6
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
what kind of springs are you using on them? i can't beleive your complainnig about a nice ride even though it handles well
slideways2004 is offline   Reply With Quote
Old 04-09-2006, 04:17 PM   #7
yudalicious
yudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond repute
wth, stiffness != good handling... period
and it depends on the springs
yudalicious is offline   Reply With Quote
Old 04-09-2006, 04:51 PM   #8
OptionZero
OptionZero's Avatar
I don't believe stiffness is always more desirable. There are diminishing gains at some point, and you're also limited by the chassis itself.
Besides, what are you talking about? stiff dampers? stiff springs? stiff chassis? stiff bars?
If stiffness were all that matters, then why do shopping carts handle like shit?
OptionZero is offline   Reply With Quote
Old 04-09-2006, 04:52 PM   #9
sunnys14
sunnys14's Avatar
sunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nice
they need power steering and bigger tires
sunnys14 is offline   Reply With Quote
Old 04-09-2006, 05:02 PM   #10
SoSideways
SoSideways's Avatar
Shopping carts drift awesome.
For grip, load all your shit on the back of the cart, and the car will turn well.
For drift, have your gf stand on the front of the cart's frame (just in front of the front wheels) and you'll drift the cart nicely.
Old 04-09-2006, 05:03 PM   #11
Irukandji
Don't forget the Watanabe rims, cup holder, and tofu sticker
Irukandji is offline   Reply With Quote
Old 04-09-2006, 05:05 PM   #12
EchoOfSilence
more like they need a setup that allows them some travel so they can actually fucking turn instead of understeer.
anyway, i don't know why we're arguing about shopping carts. hahaha
Spring constants should be chosen based on how much load will be put on them and how much travel you want them to undergo in order to produce desirable effects that lead to the steering characteristics you want.
if you want stiffer shit, get stiffer springs, but don't hate on koni yellows.
Old 04-09-2006, 05:39 PM   #13
Irukandji
We're not arguing.. we're joking.
To the post starter: did you buy Koni's because you wanted a rough ride?
If yes: you're dumb
If no: then be quiet because the shocks are fine.
Old 04-09-2006, 05:54 PM   #14
EchoOfSilence
If yes: you're dumb
i replied to your post w/o looking at who posted it, so I couldn't tell hahahh
Old 04-15-2006, 07:09 PM   #15
EchoOfSilence
in any case scenario, you'd want the tallest stiffest lowering springs out there available. too low of a spring and your konis or whatever brand name shocks become useless since you'd lose variable compression and overall shock travel.
