output shaft seals
okay, so i'm installing my diff here in a few days. i was looking at the output shaft seals, and there are two different components i see. one is a small roundish rubber looking deal, and the other is a metal piece with a flared lip. the metal one almost looks like some sort of bearing. i'm curious. are both of these wear parts? should i just get the new rubber seals, and only replace the metal ones if mine are damaged? thanks.
hmm, i see. but do i need both the metal and rubber parts?
http://www.oreillyauto.com/EW3/Produ...riptionId=1091 |
![]() Join Date: Feb 2006
The spacer before the adjust shims?
What are you doing exactly? If you are changing LSD's I would recommend re-shimming it... If you are not, then just change the seals or you could throw off the adjustments made for your current LSD... |
i'm changing the differential. on the fsm diagram, there is only one "side shaft seal" listed, so i don't know why o'reilly has two different parts labeled the same thing.
Let me know the parts you are looking for... I give zilvia members below wholesale pricing on OEM Parts...
Here is a blow up of all the parts in your differential... If you are changing only your differential (and not touching your pinion) then you should need the 2 side seals, 2 side spacers, and the 2 adjust shims, ![]() |
