Old 05-23-2002, 09:20 PM   #1
mrdirty
mrdirty is an unknown quantity at this point
Ok I had to cut the bolts in 2 places but I got the t/c rods out of the car. I then proceeded to burn out the old bushings, no problem.
Now, there are 2 rings on either side of the t/c rods that appear to be keepers but i dunno if they should come out or not. They seem pretty determined to stay in there but the bushing doesn't fit too well w/ them.
Also there are some protrusions in the bushing seat, like little bumps 1/8" high and the size of a penny w/ little nipples in the middle. Do I file these down?
I know someone knows the answers to these questions and i really need my car running ASAP so help a guy out would ya?
Thanks enormously in advance...
mrdirty is offline   Reply With Quote
Old 05-23-2002, 09:36 PM   #2
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
i don't know why it took u so much work to get the tenson rod off, mine came right off after the bolts were lose...
but, i don't recall there was any gasket in there... again, i didn't exactly look...
edit: btw, u can see my eastbear tension rods on the right side of the pic in my signature.  where the red wire is, it's chromish...
240meowth is offline   Reply With Quote
Old 05-24-2002, 04:42 AM   #3
mrdirty
they're little metal rings on the inside lip on either side of the bushing sleeve. i think they should come out but not entirely sure. As it stands now the bushinge sleeve is narrow at both ends and wide in the middle w/ these little nipples and bumps.
I hope i get an answer soon...
Old 05-24-2002, 08:05 AM   #4
mrdirty
ok, now i'm determined; I'm going to try to remove this sleeve and see what's what.
Anyone have any insight here?
Old 05-24-2002, 08:40 AM   #5
mrdirty
OMFG they're in!
Ah ha ha, in like a dirty shirt!
Old 05-24-2002, 09:00 AM   #6
sykikchimp
WOW addicted
sykikchimp's Avatar
GOOD Job!..  please explain what you found?  whats the deal with those rings and nipples (huh huh huh)..?
Old 05-24-2002, 09:31 AM   #7
mrdirty
I'll post pics tonight, unfortunatelly I didnt' get any of the inner sleeve 'cause i went from pissed off to exctacy in like 10 sec there when they popped in.
This is what I did:
Removal:
1) Remove all nuts w/ wrench and cheater bar.
2) Try to remove the main bushing bolt.
3) If siezed (as mine was) get under there w/ a work light and a hack saw after jacking it up.
4) Cut the narrow part of the bolt right tight to the bracket on the inside of the nut side.
5) Cut the other side thru the crush tube as close to the bracket on the inside as possible.
6) Burn out the rubber part of the bushing w/ a torch
7) Enjoy cool lava-like effect of silicone burning.
8) Cut a seam down the 3 parts of the inner sleeve (2 retaining rings and the core) I dis-assembled and re-assembled the hack-saw w/ the blade thru the sleeve to cut.
9) Hammer or pull the parts out.
10) Clean the bushing seat all nice nice.
Installation:
1) Get a big ass vice.
2) Lube up everything (I used Astroglide, it's a sex lube but it works GREAT on auto parts, designed by NASA)
3) Find a suitable mandrel ~2" Dia. and Short enough for the vice.
4) Put the bushing against the bushing seat and the mandrel against the other side of the bush and SQUEEZE.
5) POP! they go in like butter.
6) Jam 'er back in and torque to spec w/ new bolts and nuts.
The cheapest shop wanted (in CDN$ mind u) $200 removal installation of rods, would not go near bushings removal or installation; another shop to change bushings: $100.
jim
Old 05-24-2002, 10:28 AM   #8
MorganS13
MorganS13 is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (mrdirty @ May 23 2002,11:31)</td></tr><tr><td id="QUOTE">2) Lube up everything (I used Astroglide, it's a sex lube but it works GREAT on auto parts, designed by NASA)</td></tr></table><span id='postcolor'>
HAHA! am i the only person thats rollin on the ground cause of this. &nbsp;i'd like to see the look on the cashiers face checkin out with this, "...oh its just for my car... NO REALLY!!"
MorganS13 is offline   Reply With Quote
Old 05-24-2002, 11:05 AM   #9
mrdirty
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (MorganS13 @ May 24 2002,11:28)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (mrdirty @ May 23 2002,11:31)</td></tr><tr><td id="QUOTE">2) Lube up everything (I used Astroglide, it's a sex lube but it works GREAT on auto parts, designed by NASA)</td></tr></table><span id='postcolor'>
HAHA! am i the only person thats rollin on the ground cause of this. i'd like to see the look on the cashiers face checkin out with this, "...oh its just for my car... NO REALLY!!"</td></tr></table><span id='postcolor'>
I happened to have some <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Old 05-24-2002, 11:07 AM   #10
mrdirty
A couple months back my girlfriend asked my where it was and when i said that it was in the garage she said:
"what are you DOING to your car!?"
I laughed my ass of THAT day , i tell you what!
Old 05-24-2002, 12:09 PM   #11
DSC
New Title
DSC is an unknown quantity at this point
<!--QuoteBegin--mrdirty+May 23 2002,2<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (mrdirty @ May 23 2002,2<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>7)</td></tr><tr><td id="QUOTE">A couple months back my girlfriend asked my where it was and when i said that it was in the garage she said:
I laughed my ass of THAT day , i tell you what!</td></tr></table><span id='postcolor'>
Hahaha! Thats great.
So the final thing is the metal rings DO come out and do NOT have to go back in?
Also, what did you put in first? &nbsp;The bushing into the t/c rod and then the metal center...or the metal center into the bushing and then into the t/c rod?
DSC is offline   Reply With Quote
Old 05-24-2002, 12:28 PM   #12
mrdirty
Yep, take all the junk out.
When you're done it's all ready to get the transplant
Old 05-29-2002, 02:33 AM   #13
drifting240racer
drifting240racer is an unknown quantity at this point
I am rolling on the floor at that!! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> . &nbsp;I think you should send that into astroglide as a new use for their product. hehe maybe you might get a new tube to use ... other places... but we don't want to know so please don't tell us.
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'> &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
and i have to give you a &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'> for thinking about that... or should i be wondering why you thought about that.
drifting240racer keeping it &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cool.gif" border="0" valign="absmiddle" alt=''> &nbsp;and pondering what else i can use astroglide for &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sigh.gif" border="0" valign="absmiddle" alt=''> &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/dozingoff.gif" border="0" valign="absmiddle" alt=''>
&quot;OUT DRIFTING, if anyone wants me they have to catch me :-D&quot; --me
1993 240sx coupe --wrecked
1966 3/4 Ford pickup IT CAN DRIFT... ok it can powerslide :-)
drifting240racer is offline   Reply With Quote
