Old 04-28-2006, 08:09 PM   #1
EMC2
EMC2 is an unknown quantity at this point
sr loud ticking please help!
the morning after a hard run i noticed a loud ticking not the normal sound of my injectors firing. it louder I can hear it in the car. i poked around with a stethoscope and its loudest at the front of the head. it does not get a lot faster with the rpms a little but nothing like a spun bearing (at least i dont thing and hope) could air get in the lifters that fast, could it be timing chain, is there an easer way to tell what it is? thank you for any help. oh and im useing moble 1 10/30
EMC2 is offline   Reply With Quote
Old 04-29-2006, 10:42 AM   #2
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
im gonna say air in the lifters but idono.
mjjstang is offline   Reply With Quote
Old 04-29-2006, 11:00 AM   #3
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
i've heard of injectors clicking but u said its from the front so i suggest opening the valve cover and taking a look.
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 04-29-2006, 11:24 AM   #4
EMC2
ok i turned the car over for a few seconds with the valve cover off and on the intake cam second lobe i hear a tick every revolution and it sounds like my tick. so it is air in my lifter? if i change to a lighter oil will that help? or do I have to bleed them? any easy way to bleed it? thanks guys for your help!
Old 05-01-2006, 02:25 AM   #5
JustMe
JustMe is an unknown quantity at this point
JGY Customs has some helpful information for you (even has a picture, cant beat that with a baseball bat). Best of luck.
http://www.jgy.cc/infolinks.htm
JustMe is offline   Reply With Quote
Old 05-01-2006, 10:02 AM   #6
WILDACEX187
well according to that its your lifters so follow that procedure to get rid of it.
Old 05-01-2006, 10:57 AM   #7
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
Well, if it is on the second lobe, its the lifters. The easiest way to bleed and re-prime the lifters are to pull them out (dont scratch them up when you do it)... and set them in a small container of oil.. preferably one that is clear so you can see it... then simply tap the bucket on the sides... or like I do... just lightly drop it from about half an inch off of the ground... you will notice the air bubbles coming out of them. I would keep doing this until you see NO MORE sign of air coming out of the lifters. Then when you install them.. make sure that you hold the lifters as vertical as possible before the installation, so that way the surface tension of the oil keeps itself from coming back out.
daryl337 is offline   Reply With Quote
Old 05-01-2006, 10:58 AM   #8
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
I was about to say lifters. Goodluck on getting your engine back to normal
Drift Indy
Edgar is offline   Reply With Quote
Old 05-01-2006, 02:30 PM   #9
Rezlo
Rezlo is an unknown quantity at this point
Send a message via AIM to Rezlo
If its a VVT SR20 they are renound for the VVT solonoid going to hell and it makes a terrible noise, super fast way to check is to pop the electric connector off the VVT oil solonoid right neer your Throttle possition sensor, if the rattle goes away you have your problem, swap 1X cam gear with a Sentra or other easily available SR20 cam gear,
Another thing that loves to tick is the top cam chain guide/ usless pos, open valve cover remove 2X 12mm head bolts and turf the top guide, it isnt needed.
Rezlo is offline   Reply With Quote
Old 05-02-2006, 11:06 AM   #10
EMC2
after looking at it even more its somewere in the timing chain area and I already took off the top guide and it didnt help could it be something else in that area?
Old 05-02-2006, 12:51 PM   #11
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
Stupid question, but have you checked your oil lately? if you are running low, the tensioner wont hold the chain tight enough causing slack in the chain which results in a similiar ticking noise.
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 05-02-2006, 02:25 PM   #12
Rezlo
Very true, as soon as my S14 oil level goes lower than 1/2 way on the cross hatches on the dip stick i can hear it rattle a little,
One thing that works well for generaly noisy motors is a good engine flush to free any deposit build up and sludge, just make sure to get it all out before re-filling,
What i normally do is throw a can of flush into the current dirty oil, idle for 10 mins, drain, new cheapie filter and junk oil and another can of flush, run for 10 minutes drain totaly then refill with a semi synthetic for 500 miles then go back to full syn with a good filter, normally sorts out any noisy lifters and sticking rings and so on.
Old 05-02-2006, 02:30 PM   #13
riznuki2
riznuki2 is an unknown quantity at this point
does anyone know if a sr20det fwd head will work on a sr20det rwd?
i need a head fast.
rick mastersundefinedundefined[email protected]
riznuki2 is offline   Reply With Quote
Old 05-02-2006, 03:02 PM   #14
s13coupedrfter
s13coupedrfter's Avatar
s13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond repute
I had this problem too. It was a bad lifter. If you ever get cams it will make the problem worse. I had the HKS 264 in/ex installed and TICK-TICK-TICK. Got rid of the problem with the HKS lash killer kit.
s13coupedrfter is offline   Reply With Quote
Old 05-02-2006, 03:33 PM   #15
jdm_s14_zenki
jdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of light
Send a message via AIM to jdm_s14_zenki
i just recently had a tick in my head. pulled off the valve cover. it ended up being that one of my rocker arms came off the valve retainer. because. my rocker arm/valve spring retainer shim (the one with the guide) broke.
If its comming from the chain, your chain is loose. Check to see if the chain tensioner is working right. also, if looking at the front of your head, the right side of the chain needs to be tight (no slack) and the top of the chain must be tight, the left side must be loose, and thats where the chain tensioner comes in. when you install the chain tensioner (you squeez the spring loaded tensioner down, use the hook to hold it in place, then you slip it in the head, bolt it down, and make 2 full crank revolutions to release the hook on the tensioner.) doing this will tighten the slack on your left side. if low on oil, your tensioner will act funny. because. your tensioner relies on the oil to get rid of any slack in your chain (kinda works like a shock absorber)
jdm_s14_zenki is offline   Reply With Quote
