Old 05-27-2002, 03:02 PM   #1
MarketPlayer
MarketPlayer is an unknown quantity at this point
I have heard both arguments, but none of them ever really provided proof as to which is more efficiant for turbo and N/A!  From what i understand...the SOHC is better for lower boost b/c the the air's velocity is higher and creates more torque, and a DOHC is better for higher boost b/c it won't limit the flow of the air as much...  As for N/A I would say that it would be the same right?  Low rpm's (daily driver) SOHC would create more power, and higher rpm's would create more horsepower by flowing more air?  If i am off by a little or a lot please tell me, because i want to build up a turbo 240sx and a N/A 240sx, and need to know which model to buy!  If SOHC is better for N/A then i will build my 1990, but if DOHC is better then i will need to buy a 1991+ 240sx, and then will swap out the KA24e w/ a rb20det, and build the KA24DE.
thanks in advance,
-zac
MarketPlayer is offline   Reply With Quote
Old 05-28-2002, 05:50 PM   #2
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
DOHC is better either way because turbo kits are easier to find <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> this is coming from someone who has a SOHC.
02 Blazer X - 90 240SX w/SR
oh noes
whateverjames is offline   Reply With Quote
Old 05-28-2002, 06:56 PM   #3
MarketPlayer
I don't care about availability, just efficiency!
Old 05-28-2002, 07:15 PM   #4
rubbersidedown
rubbersidedown's Avatar
rubbersidedown is an unknown quantity at this point
first of all, this topic doesn't belong in chat, it belongs in the tech section. i wonder why it hasn't been moved there already. Secondly, both engines are good. And in what way do you mean effecient? both engines have their good and bad points. Pick one and use it. Part of the fun of building up a car is finding out shit for yourself. Now i'm not saying to go into the whole process blindly, but when i mean is learn the basics and whatever else you can and then the rest is purely up to you. that's just my 2 cents.
1991 240sx coupe w/ ca18det
Bone stock
Purchased but not installed parts:
HKS adjustable timing gears
Electronic Oil Pressure Guage
Apex'i Multichecker
t3/t04b turbo
Stainless Steel, top mount tubular manifold
ARC bov
450cc injectors
Spearco FMIC
rubbersidedown is offline   Reply With Quote
Old 05-28-2002, 07:43 PM   #5
MarketPlayer
ok, could someone please move this to the tech section? &nbsp;By efficient i mean, &nbsp;Is a DOHC going to make more power if all things are equal or will a SOHC, when going N/A? &nbsp;And the same for turbo. &nbsp;All i want to know is which setup is best, when building a naturally aspired engine? &nbsp;Forget about the turbo...Just N/A...I have decided officially on the RB20det for my turbo engine. &nbsp;Please someone provide so really good insight into this. &nbsp;thanks
-zac
Old 05-28-2002, 09:10 PM   #6
rubbersidedown
i say go w/ the ka24de, specifically from a '91 240sx. The '91 is known to have the more agressive cams and on top of that the ka24de is newer. I know that doesn't necessarily mean the engine is better but i think that a new model engine would be made to be a little better than the previous.
Bone stock
Apex'i Multichecker
t3/t04b turbo
ARC bov
450cc injectors
Spearco FMIC
