Old 05-10-2006, 01:10 AM   #811
usdm180sx
usdm180sx's Avatar
Originally Posted by chmercer
dude, you are a fucking clown. you obviously have no idea how coilovers work. it has been simply explained to you like 4 times. preloading a spring raises your car, drooping a spring lowers your car. done.
Really? So you run no preload to slam your car? How does that affect your drifting efforts? Wait, IIRC you only have 200whp and you run 18x12 wheels out back? LOL how do you even drift??? Your car must handle pretty lame.
-Norm!
usdm180sx is offline
Old 05-10-2006, 01:17 AM   #812
chmercer
chmercer's Avatar
"preload doesnt raise your car... it raises your spring rates. the strut can only go so far up."
NO
preloading does not raise your spring rate
preloading does not lower your car
drooping the spring lowers your car
preload shifts weight; increasing preload in the front shifts weight to the rear (by lifting the front of the car) and also alters your shock travel.
stop using "hmm this sounds right because i looked at my suspension for 5 minutes" logic and start learning how things actually work.
chmercer is offline
Old 05-10-2006, 01:25 AM   #813
chmercer
chmercer's Avatar
dude how stupid can you fucking be
heres how you lower a car
front
remove all except 1 spring perch
thread bracket until it touches the bottom of the spring perch (NO PRELOAD)
done, this is the max lowness you can acchieve with s chassis front suspension
rear
bottom out the shock bracket
droop the spring down the shock body as far as you want, keeping in mind that you loose shock travel when doing so (NO PRELOAD)
done, this is the max lowness you can acchieve with s chassis rear
if you do anything else than this, your car is not as low as it could be
for the rest of your questions -
my car handles awesome, because i know how to set it up, i have full shock travel in the front and rear (never hit the bumpstops)
i dont know how much power i have? ive never been on a dyno and dont plan on being on one soon. yes i drift on 18x12 rear wheels?
and as for how i drift - i know how to drive
chmercer is offline
Old 05-10-2006, 01:26 AM   #814
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Wait doesnt it also depends on wut coilovers you have??? Some coilovers you can adjust the ride height seperately without messing around with the spring perch. I know some Teins, you can only lower the car by lowering the spring perch. Your lowering the car but your effectively changing the shock travel too.
CLICK HERE!!!
fliprayzin240sx is offline
Old 05-10-2006, 01:27 AM   #815
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
"When you move the spring perch upwards, you are compressing the spring. As the spring compresses, it exerts a force on the upper mount of the coilover. So when the weight of the car is placed on the upper mount, the weight would have to overcome the spring tension in order to compress the spring any further. Placing the spring under tension is called "pre-loading" the spring."
Straight from spl
Moving the spring perch upwards (preloading) raises the ride height, moving the spring perch down lowers the ride height
Thankyoucomeagain
az_240 is offline
Old 05-10-2006, 01:28 AM   #816
chmercer
chmercer's Avatar
yeah crappy single height adjustable coilovers you have to droop the spring to lower them at all
with most coilovers nowadays you can lower the car a good deal by changing the mounting point of the shock, before you have to start drooping the spring and sacrificing shock travel.
chmercer is offline
Old 05-10-2006, 01:36 AM   #817
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
ok... IMO drooping the spring is stupid, you dont lower the spring to lower your car, your shocks will probably blow significantly sooner. people lower the spring becasue they have maxed out their coilovers and thats the only way they can lower their car more.
preload raises your car, simply put.. for every action, there is an equal and opposite reaction. This is Newtons 3rd law
as you compress the spring more, it will exert a force on the shock, that added force will raise up the car since the same force as before (mass of car and gravity) will still be exerted on the shock.
there done and done.. stop arguing, keep this a picture thread on how low can you go
btw usdmsiliva... stop spitting out all this crap when you definatly do not know physics.
Sfourteen
dct223 is offline
Old 05-10-2006, 01:47 AM   #818
yokotas13
yokotas13's Avatar
Dream on cowboy. Do you honestly believe that raising preload raises your car??? Man you really ARE stupid (AND sadly misinformed) if that's the case
actually it does....but htats besides the point
yokotas13 is offline
Old 05-10-2006, 01:53 AM   #819
that180guy
that180guy is making a name for him/her selfthat180guy is making a name for him/her self
Send a message via AIM to that180guy
:lmao: my boy davis just skooled ALL of you.!!!
(and yes i kno my post is pretty useless )
now on with pics of slammed S/Z chassis's!
LP stylez!! bishes Lazy Penguin since teh 04'
Part of the Elite Shasta Speed Stars
RIP......05-09-03....*sniff sniff
the beast nears completion.....
YOU LOOK AND U BUY STUFF !!!!!
that180guy is offline
Old 05-10-2006, 02:05 AM   #820
!Zar!
!Zar!'s Avatar
usdmsilvia: You are basing your suggestions off of a single damper with zero weight attached.
We are all talking about adjusting your car in real life situations ie, on the car.
Raising the spring collar up raises the bottom of the spring up, and with nowhere for the top to go, it is compressed. I hope you remember what happens when you push down on a spring, but just incase, I'll refresh your memory. The spring rate goes up.
And being as how the spring rate goes up, it's force pushes outward, and that outward force raises the car.
Changing preload, is a way you can adjust and account for droop and ride height settings.
!Zar! is offline
Old 05-10-2006, 02:19 AM   #821
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
usdmsilvia: Go cut off your own head and throw it in the garbage.
You, sir, are useless.
Think about it... when the pre loaded spring pushes up on the upper mount, there is no "visual" change in "ride height" when the car is jacked up and the suspension and shock is at full droop. Once it gets lowered off the jack and the vehicle is sitting on the ground, the ride height WILL BE HIGHER (assuming you left the lower height adjusting brackets untouched). It will take more force to compress the spring, and since the effect of gravity will compress an unloaded spring more than the preloded one, the sprung weight (the fucking car) will sit lower with no preload. AND THUSLY, HIGER WITH PRELOAD.
God.
Die.
What is that? The 9th time its been explained to you? Damn.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline
Old 05-10-2006, 02:25 AM   #822
mrmephistopheles
mrmephistopheles's Avatar
enough of this crap or I'm going to ball this thread up, eat it, crap it out, then make you guys eat it.
LOW CARS.
PICS.
SPECS.
MAKE IT FUCKING HAPPEN.
No fake-low shit (ooh my 8" garden trim lip totally scrapes!!!/ zOMG I'm so slammed on 14"s with 185/35s!!) either!
QUIT THE BITCHING, MAKE WITH THE SLAMMING.
Originally Posted by PHLIP
mrmephistopheles is offline
Old 05-10-2006, 02:39 AM   #823
quach
quach is an unknown quantity at this point
i dont know if you guys would consider my car really that low, but this is probably the lowest it will ever be for me, it sucks to drive. running KTS dampers with 15x7 +0 wheels all around.
quach is offline
Old 05-10-2006, 03:34 AM   #824
NemeGuero
No more nissan.
NemeGuero's Avatar
Thanks for the pre-load argument guys.. really explained a lot and cleared some things up!! keep at it slammed kings.
NemeGuero is offline
Old 05-10-2006, 07:18 AM   #825
S13SilviaGirl
UGH Really?
S13SilviaGirl's Avatar
S13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfection
will be lower as soon as we get home....YAY!
My Review Thread
Originally Posted by DTCSuperstar
I surf Zilvia naked in my home...
S13SilviaGirl is offline
Old 05-10-2006, 08:26 AM   #826
nokeone
on strike three.
nokeone's Avatar
nokeone is making a name for him/her selfnokeone is making a name for him/her self
Send a message via AIM to nokeone Send a message via MSN to nokeone Send a message via Yahoo to nokeone
Originally Posted by EchoOfSilence
he's had it for a while, apparently.
I've seen it driving by campus a couple of times, it's pretty loud. I digress....
dude...say hi...lol..
i live on western dr. so i pretty much drive by campus every day..
panda; rockin your socks from the Bay to LA to SD, yay!
Pink GodziRa
nokeone is offline
Old 05-10-2006, 10:54 AM   #827
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
I adjust my car's ride height through preload. . . (Tein SS) FS next week.
Then I'll get more low pics!
FaLKoN240 is offline
Old 05-10-2006, 12:04 PM   #828
DavidC
DavidC is just really niceDavidC is just really niceDavidC is just really niceDavidC is just really niceDavidC is just really niceDavidC is just really niceDavidC is just really niceDavidC is just really niceDavidC is just really nice
Originally Posted by spools14
Damn man... you're car is completely differnt since I saw it last at the JDMSC meet..
New wheels and kit look really nice, throw spacer up front when u lower it tho
BTW this is Chris that used to own the Soarer.
yo chris
wsup yea i changed it up over the winter months.
its got a 5mm spacer on there now and my only other spacers are 20mm bolt on. i dont think i'll be able to fit those on without new fenders. i might go up to a 235/40 up front to till it up a bit since it looks quite sunk to me up front.
DavidC is offline
Old 05-10-2006, 03:25 PM   #829
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Bucket?
Old 05-10-2006, 04:32 PM   #830
SilviaNinja240
SilviaNinja240's Avatar
SilviaNinja240 will become famous soon enoughSilviaNinja240 will become famous soon enoughSilviaNinja240 will become famous soon enough
you live in a nice neighborhood scott! +1 for San Mateo
SilviaNinja240 is offline
Old 05-10-2006, 06:45 PM   #831
spools14
spools14 has much to be proud ofspools14 has much to be proud ofspools14 has much to be proud ofspools14 has much to be proud ofspools14 has much to be proud ofspools14 has much to be proud ofspools14 has much to be proud ofspools14 has much to be proud ofspools14 has much to be proud ofspools14 has much to be proud ofspools14 has much to be proud of
Almost all street use coilovers were designed to adjust ride height by adjusting preload just a couple years ago.
Clearly mr usdmsilvia has been misinformed.
spools14 is offline
Old 05-10-2006, 08:15 PM   #832
Team Rootbeer
Team Rootbeer's Avatar
Team Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really niceTeam Rootbeer is just really nice
Send a message via AIM to Team Rootbeer
had a little fun after local auto-x:
raised up about .5in all around from daily height for the autocross, bc our course is pretty shitty in some spots
just got done surfacing the car yesterday, sealer today, then base/clear tommrow, then ill get some more low pics w/ shiny new black paint!
just noticed how massive my rear tires are, i gotta get rid of the 275s!
Originally Posted by hotrodv
90% of the cars posted here are stock or with original rims painted black
I'm not an asshole but is the true..
Team Rootbeer is offline
Old 05-10-2006, 09:05 PM   #833
Irukandji
Scott: 4.5 lug FTW! Did you get Stance coils?
Irukandji is offline
Old 05-11-2006, 12:38 AM   #834
Johny5
Johny5's Avatar
ummm yeah thats raised about an inch to get into his garage, time to go looooooooooooooooower.
nvm the ghetto fmic bracket, was just there for test fit
www.stewartleask.com
Johny5 is offline
Old 05-11-2006, 01:20 AM   #835
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
Knock it off!
No more pics from you until that thing is standing all candy red-orange and glorious. OR ELSE!!!!!!!
Juanito Cinco FTL!
hahahaha its ok, i still love you.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline
Old 05-11-2006, 01:23 AM   #836
Johny5
Johny5's Avatar
it's getting closer though babe
haha can only put 2-3 hours into it a day, really slowing shit down a LOT!!!
Johny5 is offline
Old 05-11-2006, 01:27 AM   #837
Ricks15
Ricks15's Avatar
Ricks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud of
What happend to you're S14? why did you take it all apart? doing body work
Ricks15 is offline
Old 05-11-2006, 01:30 AM   #838
Johny5
Johny5's Avatar
it is getting full repaint and a few goodies. wanted to get the new paint everywhere, not just jams and exterior. so we dismantled the whole car.
Johny5 is offline
Old 05-11-2006, 01:35 AM   #839
Ricks15
Ricks15's Avatar
So what you're new color, you're still KA-T huhh I remember seeing you're clean ass kouki in the picture thread a while back. Fucken sick ride man hope it comes out bad ass, Or Better than Dousan's Kouki
Ricks15 is offline
Old 05-11-2006, 03:00 AM   #840
McRussellPants
Oh shit, its on now.
Its a close race. Perhaps if one of them were to man up and buy Kuah's Works 9 bumper it could be decided. (please god do it before he puts it on an S13)
McRussellPants is offline
