Old 05-27-2006, 01:14 AM   #1
crashtestdummy
crashtestdummy's Avatar
crashtestdummy is an unknown quantity at this point
Send a message via AIM to crashtestdummy Send a message via Yahoo to crashtestdummy
Question no spark problem
well i just swaped a 98 dohc into my 90, im using a s13 dohc harness, computer, and intake. everything works, expect im getting no spark. I have power to the coil, the injectors are pulsing (checked with noid lights) all my grounds are hooked up. anybody have any ideas????? this thing is drivin me nuts
thanks
crashtestdummy is offline   Reply With Quote
Old 05-27-2006, 10:30 AM   #2
SiLviAgYrl
SiLviAgYrl is making his/her stupidity well-knownSiLviAgYrl is making his/her stupidity well-knownSiLviAgYrl is making his/her stupidity well-knownSiLviAgYrl is making his/her stupidity well-known
hrmmmm.. anyone know cuz im stuck on it too.
SiLviAgYrl is offline   Reply With Quote
Old 05-27-2006, 07:58 PM   #3
Markovich
Markovich's Avatar
Markovich is an unknown quantity at this point
did you check your timing? and all your wires,
Markovich is offline   Reply With Quote
Old 05-27-2006, 09:54 PM   #4
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
Yea timing is a big issue, you have to be sure it is 100%. Is your distrobutor in at #1 on TDC. If you are sure of your timing, check you distrobutor, cap, rotor.
NIK90s13 is offline   Reply With Quote
Old 05-28-2006, 12:45 AM   #5
crashtestdummy
yea im pretty shure about the timing, i brought the motor up on tdc #1 cylinder and wired it from there, it has a new cap and rotor too
Old 05-28-2006, 09:34 AM   #6
Markovich
Markovich's Avatar
was it tdc on exhaust or power?
Old 05-28-2006, 03:22 PM   #7
crashtestdummy
im pretty shure it was on power, but i'll check again.
Old 05-28-2006, 08:41 PM   #8
Markovich
Markovich's Avatar
either put your finger over the spark pulg hold and have a trustwerthy friend just tap the key over until it pushes your thumb off the hole then stop and put it at tdc then. what might be happen is its sparking on every exhaust.. lol hope you firgure it out
peace
~sr20 powered
Old 05-29-2006, 03:14 PM   #9
crashtestdummy
hey thanks, i finally figured it out, it was one of those stupid things i didnt tighten the screw allthe way down on the computer harness plug so the four wires in the center that just happen to fire the coil, wernt touchin.lol well thats what i get for trying to stay up all night doing a engine swap =)
thanks again
