Old 06-08-2006, 06:24 PM   #1
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
Weird Idle Problem
Ok, I picked up a 1990 240 with the sohc, that needed a timing chain job. Finished the timing chain and put everything back together. Finally, got it started correctly with the right timing and then replaced the battery because it was completly dead. It Idle fine after the timing chain job and start up, but after the first drive when I put the car back into park the idle jumped up to about 2200 rpm. I can't get it to go back, where should I start? I don't think its the TPS.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 06-08-2006, 07:08 PM   #2
skylinekin
skylinekin is an unknown quantity at this point
check for vacuum leaks and make sure the tps is properly secured, and you might want to check the mafs.
skylinekin is offline   Reply With Quote
Old 07-19-2006, 08:45 PM   #3
Gjohnson7
Any other ideas? I can't seem to find a vacuum leak anywhere. But I've tried playing with the TPS and there is no response what so ever. Does anyone have a pic of the TPS on hte SOHC just for clairifacation. It should be the harness connected to the trottle body right? I can rev the engine with it plugged in or unplugged and there's nothing.
Old 07-20-2006, 05:42 PM   #4
Gjohnson7
Anyone????????????
Old 07-20-2006, 07:42 PM   #5
s13coupedrfter
s13coupedrfter's Avatar
s13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond repute
Try to bring it down with the idle adjustment screw then see if it's holding steady. May also try to clean out or replace the iacv
s13coupedrfter is offline   Reply With Quote
Old 07-22-2006, 03:36 PM   #6
Gjohnson7
Problem fixed. Yeah, I had to get some cleaner and clean out the Iacv. After it was cleaned real good, I realized that s13coupedrfter was right, the previous owner had set the idle as high as it would go, to avoid the car from dieing with the dirty Iacv. Thanks for your input guys!
Old 07-23-2006, 01:41 AM   #7
s13coupedrfter
I'm stoked to hear it worked out for you! Good job
Old 07-23-2006, 01:48 AM   #8
s13coupedrfter
Almost forgot, an oil catch can could help reduce the gunk that ends up plugging the iacv too.
Old 09-23-2006, 10:03 PM   #9
MacDrevi0us
MacDrevi0us is on the path to ruinMacDrevi0us is on the path to ruin
wuts an iacv?
MacDrevi0us is offline   Reply With Quote
Old 09-24-2006, 07:57 PM   #10
95240sxmjm
95240sxmjm's Avatar
95240sxmjm is not welcome here anymore95240sxmjm is not welcome here anymore95240sxmjm is not welcome here anymore95240sxmjm is not welcome here anymore95240sxmjm is not welcome here anymore95240sxmjm is not welcome here anymore95240sxmjm is not welcome here anymore95240sxmjm is not welcome here anymore95240sxmjm is not welcome here anymore
Idle Air Control Valve (IACV)
95240sxmjm is offline   Reply With Quote
Old 10-04-2006, 08:06 PM   #11
MacDrevi0us
muchas gracias
