Old 06-09-2006, 09:08 AM   #1
toledo240
toledo240's Avatar
toledo240 has a little shameless behavior in the past
cracked spark plugs around white housing
I have a redtop sr20. Running off of bkr6e's. I keep on cracking the white part on the plugs and causes bad detenation. It running lean when at had it a 12psi but now im back to stock boost and i ant get the problem to go away. It sounds like my car is running off 3 cylinders or sounds real low like an sti motor or something. Give gas to pedal causes smoke out the exhaust, (more than usual)i think this is running rich. Everything ive done is check for spark, check connections. Im thinking my fuel pump went bad
toledo240 is offline   Reply With Quote
Old 06-09-2006, 09:26 AM   #2
AuburnRyan
AuburnRyan is an unknown quantity at this point
Check gap is at ~ .0029. Try the BKR7E - I imagine they're cracking because they're too hot...
Sorry, confusing post, first you say leanat 12psi, then rich at 7psi?
Have you upgraded the fuel system?
'93 Fastback LE - Wrecked
'91 Fastback HICAS and LSD - Sold
'93 Fastback SE - Current
AuburnRyan is offline   Reply With Quote
Old 06-09-2006, 10:09 AM   #3
toledo240
toledo240's Avatar
i figured it out messing with the gap of the spark plugs, i was running a larger gap. but now with the gap at about .32 i get a lot of smoke out of the exhaust more than usual and smell alot of gas, is that because i shorten the gap? anything i can do about that. im running not cat or no afc
Old 06-09-2006, 02:08 PM   #4
smithers584
smithers584 is an unknown quantity at this point
well first off .32 is way too big, try .032! im sure that was a typo, right? anyways, you could go smaller, .028-.032 is usually a good way to go. how do you know if you are running lean or rich? and the cracking is either due to heat or detonation so try and get on a dyno or get a wideband and see exactly what you are at for afr. highly doubt your fuel pump went bad, are you sure you have the vacumm line on the fpr hooked up? that would cause it to run a little more rich, what about vacumm leaks have you checked for those? are you plugs are fouled up or are the white or are they a good tan? need a lot more info.
smithers584 is offline   Reply With Quote
